Dumps Submitted for Seinfeld 4K/UHD Seasons 6-9
datatracer
Post by datatracer » Thu Dec 19, 2024 5:52 pm
Just emailed my dumps for Seinfeld 4K, Season 6-9 (Amazon, US Version)
MKB20_v77_Seinfeld_Season_6_Disc_1_A7B4.tgz
MKB20_v77_Seinfeld_Season_6_Disc_2_68EC.tgz
MKB20_v77_Seinfeld_Season_6_Disc_3_4EC6.tgz
MKB20_v77_Seinfeld_Season_7_Disc_1_0112.tgz
MKB20_v77_Seinfeld_Season_7_Disc_2_DC4A.tgz
MKB20_v77_Seinfeld_Season_7_Disc_3_A3B2.tgz
MKB20_v77_Seinfeld_Season_8_Disc_1_626E.tgz
MKB20_v77_Seinfeld_Season_8_Disc_2_6348.tgz
MKB20_v77_Seinfeld_Season_8_Disc_3_235E.tgz
MKB20_v77_Seinfeld_Season_9_Disc_1_5624.tgz
MKB20_v77_Seinfeld_Season_9_Disc_2_7EA4.tgz
MKB20_v77_Seinfeld_Season_9_Disc_3_41E6.tgz
unclecarmie
Re: Dumps Submitted for Seinfeld 4K/UHD Seasons 6-9
Post by unclecarmie » Thu Dec 19, 2024 6:38 pm
Thanks, was just coming to post mine.
Toad King
Post by Toad King » Thu Dec 19, 2024 8:06 pm
It was posted in the other thread but all discs are currently in KEYDB.
brownSys
Post by brownSys » Fri Dec 20, 2024 3:10 pm
Toad King wrote: Thu Dec 19, 2024 8:06 pm It was posted in the other thread but all discs are currently in KEYDB.
I'm not quite sure what this means. Does this mean that Seasons 6-9 should be able to decrypt in MakeMKV or that they are just on the list to be added?
For me 6-9 still do not decrypt.
Post by SamuriHL » Fri Dec 20, 2024 4:19 pm
It means they were added to the publicly available keydb.cfg file that you can download from the link, extract the keydb.cfg file from the archive, and copy it to your MakeMKV folder where your tgz dumps are created. Restart MakeMKV and you'll be good to go.
brownSys
Post by brownSys » Fri Dec 20, 2024 5:39 pm
SamuriHL wrote: Fri Dec 20, 2024 4:19 pm It means they were added to the publicly available keydb.cfg file that you can download from the link, extract the keydb.cfg file from the archive, and copy it to your MakeMKV folder where your tgz dumps are created. Restart MakeMKV and you'll be good to go.
Thanks! That did the trick.
tk4207
Post by tk4207 » Fri Dec 20, 2024 6:41 pm
Having trouble with Season 7 Disc 2 even after updating to the latest keydb file- anyone else having this issue? Attached my version of the S7D2 tgz-
Post by SamuriHL » Fri Dec 20, 2024 9:11 pm
DiscID: 0xF4AA456461690E17D33A89F02B54F17C281F6433
That disc is most definitely in the keydb.cfg. Maybe re-download it and make sure it's extracted before copying it to the MakeMKV folder that your tgz files are created in.
tk4207
Post by tk4207 » Fri Dec 20, 2024 11:30 pm
SamuriHL wrote: Fri Dec 20, 2024 9:11 pm DiscID: 0xF4AA456461690E17D33A89F02B54F17C281F6433
Agreed- I see the discID in there too which is bizarre. Definitely have the unzipped .cfg sitting in the Library>MakeMKV folder as well. All other discs work without issue, including S7D1 & 3 and S8 D1 & 2 as well (still working on the remainder).
Also tried re-installing MakeMKV but no luck there either. Could this be caused by some other issue with my particular disc? Haven't run into this issue before with other rips so unsure how to best troubleshoot.
Screenshot 2024-12-20 at 5.24.46 PM.png (70.53 KiB) Viewed 15288 times
Screenshot 2024-12-20 at 5.28.28 PM.png (50.83 KiB) Viewed 15288 times
keydb_helper
Post by keydb_helper » Sat Dec 21, 2024 10:39 am
tk4207 wrote: Fri Dec 20, 2024 11:30 pm Agreed- I see the discID in there too which is bizarre. Definitely have the unzipped .cfg sitting in the Library>MakeMKV folder as well. All other discs work without issue, including S7D1 & 3 and S8 D1 & 2 as well (still working on the remainder).
What is the exact error message you are seeing when trying to backup S7D2? Is it a decryption error or a read error?
Public KeyDB Disc Submissions
brownSys
Post by brownSys » Sat Dec 21, 2024 5:23 pm
I also could not decrypt S7 D2 or S9 D3. I believe there was one or more discs in S8 as well. Unfortunately I am not in a position to give specifics right now but can later this evening.
tk4207
Post by tk4207 » Sat Dec 21, 2024 5:35 pm
keydb_helper wrote: Sat Dec 21, 2024 10:39 am
I'll be damned; tried it again (4th time) after finished the rest of the discs, and sure enough it worked! Was originally giving me a decryption error- no changes between tries, not even a restart, just worked out of the blue.
Thanks for your help, and apologies for the trouble!
adamt89
Post by adamt89 » Sun Dec 22, 2024 12:03 am
This does work, but I am noticing that I have to add the keydb.cfg in the C:\Users\%USERPROFILE%\.MakeMKV folder each and every time I scan an new disc. Is this normal?
Once MakeMKV loads, the file seems to be absorbed or deleted.
Post by Woodstock » Sun Dec 22, 2024 12:23 am
Is that your defined MakeMKV user directory? It is generally considered a temporary directory, which is why it is emptied out.
Your MakeMKV data directory (where the file should go) is defined in Preferences->General, MakeMKV data directory. This is where you should place the keydb.cfg file.
Post by SamuriHL » Sun Dec 22, 2024 1:00 am
And it should not be deleted no..
Sent from my SM-S928U1 using Tapatalk
