scpzhttty
Re: SDFtool Flasher
#1171 Post by scpzhttty » Sat Dec 21, 2024 9:10 pm
Hello!
Which firmware would be better for me to use?
My model is Buffalo BRUHD-PU3-BK.
Here are the Buffalo firmware options I found:
DE_Buffalo_BRUHD-PU3_BN12-MK.bin
DE_Buffalo_BRUHD-PU3_BU10.bin
DE_Buffalo_BRUHD-PU3_BU12-MK.bin
Are the following two firmware options also compatible with my model?
DE_LG_BU40N_1.00.bin
DE_LG_BU40N_1.03_MK.bin
Additionally, what are the functional differences between these firmware versions?
Can I use this method to unlock UHD functionality on Windows 11, Windows 10, or macOS 15.2?
Thank you!
Mr_Orange
Re: SDFtool Flasher
#1172 Post by Mr_Orange » Sun Dec 22, 2024 12:29 am
Hello!
Thank you!
The advice is to flash to BU40N_1.03MK.
Re: SDFtool Flasher
#1173 Post by Billycar11 » Sun Dec 22, 2024 12:29 am
use 1.03mk and your good
DoubleBizzy
Trouble flashing a USB LG BP50NB40
#1174 Post by DoubleBizzy » Tue Dec 24, 2024 4:49 pm
Sorry for the trouble, hoping you can help please.
I've been using this Slim Portable Blu-ra / DVD Writer BP50NB40 SVC Code NB40 for a few years on Blu-Rays and a few DVDs. Have a ~2009 Marley & Me Blu-Ray that had too many hash check errors. Read some posts, I think the disk is clean and in good shape, also realized I was on firmware 1.00 so I thought I'd upgrade the firmware. Read the old posts and the new SDFtool, and several posts about people being told to "follow the directions" and do both the write and the recover. Felt confused but tried anyway - big mistake.
Successfully wrote bp50nb40-nb50 1.03 (slim external drives) and that shows up. Now in MakeMKV the LibreDrive Information shows Firmware Type Patched (microcode access re-enabled), version 1.03. The Drive Information also says revision 1.03.
When I try to Recover to BU40N 1.03 MK, the first weird thing that happens is I click on the bin, click open, and the SDF FLasher (v1.3.5) still shows "please select a firmware to write". So I do it again and this time it appears in the menu. When I click start, it appears to work and is done in less than 5 seconds (much shorter than the write took the first time).
But now the drive doesn't really work and still shows the 1.03 information above, both in makemkv and in the flasher tool. The front button or "eject" does make the green light flash, but results in "disc is being loaded" animation and nothing happening. I've even tried manually opening and closing with a paper clip, it doesn't change the issue. Tried unplugging / replugging, tried restarting the computer.
Also tried Recover using BP60NB10 1.00 MK and had the same issues, both the the menu selection and the "done successfully" in a few seconds but no change from the first write.
So then I tried Recover to the bp50nb40 nb40 1.00 clean bin, like this post (viewtopic.php?p=129930#p129930), but it has the same issue of not loading the bin the first time I select it, "done successfully" in about 3 seconds, and having the same 1.03 info / label. So, sadly, it did not work for me.
Then tried Write using the nb40 1.00 clean as well, no effect.
What did I do wrong the first time trying to update the firmware? And what am I doing wrong on the Recover side? Thank you so much for any help you can advise, sorry for yet another newb apparently not following directions, and Merry Christmas (also, Festive Festivus)!
segfaulted
Re: Trouble flashing a USB LG BP50NB40
#1175 Post by segfaulted » Tue Dec 24, 2024 6:28 pm
To use Recover, it will prompt for 2 firmware files.
For the first one, you must choose the bin for the drive's CURRENT firmware, which you said is bp50nb40-1.03 so choose that one.
For the second file, choose the firmware bin you want to flash.
ændrük
Re: SDFtool Flasher
#1176 Post by ændrük » Fri Dec 27, 2024 4:50 pm
Just wanted to report success and say thanks! I bought an Archgon MD-8107-U3 (ASIN B07BC9F98J) identifying as an HL-DT-ST BD-RE BU40N with firmware 1.02 2120-12-01 17:16, used SDFtool Flasher 1.3.5 in VirtualBox¹ to write DE_LG_BU40N_1.03_MK.bin followed by DE_LG_BU40N_1.00.bin², and then was successfully able to read my first UHD disc using MakeMKV 1.17.8 on NixOS.
¹ Before resorting to VirtualBox I tried using the sdftool CLI for Linux but `help all` just hung.
² I tried stopping at 1.03 MK, but reads failed with "KEY NOT PRESENT" etc.
storageisfun
Re: SDFtool Flasher
#1177 Post by storageisfun » Mon Dec 30, 2024 2:01 am
I am getting an error when I click start. I have a buffalo and I am using DE_LG_BU40N_1.00 firmware.
A pop up opens and says Command Produced Error code 0xf......
storageisfun
Re: SDFtool Flasher
#1178 Post by storageisfun » Mon Dec 30, 2024 3:34 am
I was using the
BU40N 1.03 MK,
firmware as well and it didn't work either
wackzingo
Re: SDFtool Flasher
#1179 Post by wackzingo » Mon Dec 30, 2024 4:24 am
I want to start by saying thank you for all the work that's gone into these tools and guides.
I read all the instructions but want to make sure before I screw it up that I'm about to do this correctly.
First, I did a read to create the firmware dump.
Second, this is from MakeMKV:
OS device name: F:
Product: BD-RE WP50NB40
Revision: 1.03
Serial number: [redacted]
Firmware date: 2121-07-08 16:09
Highest AACS version: 65
If I understand correctly,
Select F: HL-DT-ST_BD-RE_WP50NB40_1.03_xxxx_xxx
Select Write
Select the firmware DE_LG_WP50NB40-NB50_1.03_MK.bin
Finally, do a cross flash by using the recovery option to selection the F: again with the new firmware and choose DE_LG_BU40N_1.00.bin (or do I want the BP60NB10 1.00-MK?)
Thanks again.
Re: SDFtool Flasher
#1180 Post by MartyMcNuts » Mon Dec 30, 2024 4:41 am
You cut it off. What's the error code?
Do you have MakeMKV installed in the default location?
Is the drive tray empty and closed?
Any new Buffalo drives should have encrypted firmware so ensure there is a green tick beside "Encrypted Firmware". If there is a red X, click on it to toggle it to a green tick.
Flash the drive with BU40N 1.03-MK to remove the firmware encryption, then flah BU40N 1.00 if you want to use other ripping software besides MakeMKV.
storageisfun
Re: SDFtool Flasher
#1181 Post by storageisfun » Mon Dec 30, 2024 5:52 am
I followed the steps you provided and now it shows up as
Though now when I open MakeMKV the disk icon is still spinning and it says "Disc Loading". I first downgraded it to 1.03-Mk then 1.00
storageisfun
Re: SDFtool Flasher
#1182 Post by storageisfun » Mon Dec 30, 2024 6:15 am
After leaving it in for a while it says "no disc inserted"
Re: SDFtool Flasher
#1183 Post by Billycar11 » Mon Dec 30, 2024 6:24 am
always let the os see the disc first then open makemkv
you may also have a power issue plug both cable direct to back of pc or laptop no unpowered hubs
if that dont work get a high powered usb hub 35+ watts
copy paste your makemkv drive info section so we can check you flashed it right
storageisfun
Re: SDFtool Flasher
#1184 Post by storageisfun » Mon Dec 30, 2024 6:32 am
The OS doesn't recognize the disc.
I tried attaching both the USB and Boost USB cables directly to my computer and now the drive won't even show up in MakeMKV.
So I can't share the drive information.
storageisfun
Re: SDFtool Flasher
#1185 Post by storageisfun » Mon Dec 30, 2024 6:45 am
Here is the information
OS device name: F:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: 1.03
Serial number:
Highest AACS version: 72
Firmware version: 1.03
