I am unable to access my Blue-Ray. The error message is "This Blu-ray needs a library for AACS decoding, and your system does not have it."
Could you explain what I must do?
Thanks.
AACS decoding
Re: AACS decoding
Without knowing what system you're talking about (Linux? Mac? Windows?) and what software you're trying to use, it's impossible to give you a definitive answer.
Re: AACS decoding
Sorry, my bad.
Windows 10, makemkv.com
Anything more needed?
Re: AACS decoding
You're trying to use MakeMKV on a Windows 10 machine to rip a blu-ray and you're getting that error?
JimMayor wrote: Fri Dec 20, 2024 4:24 pm"This Blu-ray needs a library for AACS decoding, and your system does not have it."
Re: AACS decoding
nah thats wording from vlc
in makmekv in settings and integration enable it for vlc
alot was left out here alot
