Updated to 1.14.7, but it keeps making my Mac restart
kingston12
Post by kingston12 » Fri Dec 06, 2019 9:51 pm
Has anyone else had the problem? When I run 1.14.7, it actually crashes my Mac. It automatically restarts, but then just crashes again when I launch MakeMKV.
Re: Updated to 1.14.7, but it keeps making my Mac restart
Post by Woodstock » Sat Dec 07, 2019 1:51 am
The Mac should be logging what's crashing it. Do you have the system log event?
kingston12
Post by kingston12 » Sat Dec 07, 2019 11:30 am
Woodstock wrote: Sat Dec 07, 2019 1:51 am The Mac should be logging what's crashing it. Do you have the system log event?
This is what it says:
*** Panic Report ***
panic(cpu 0 caller 0xffffff8012a06ee6): "mount_common(): mount of udf filesystem failed with 6, but vnode list is not empty."@/BuildRoot/Library/Caches/com.apple.xbs/Sources/xnu/xnu-4903.278.12/bsd/vfs/vfs_syscalls.c:1154
Backtrace (CPU 0), Frame : Return Address
0xffffff82f5ffb620 : 0xffffff80127af57d
0xffffff82f5ffb670 : 0xffffff80128eb065
0xffffff82f5ffb6b0 : 0xffffff80128dc79a
0xffffff82f5ffb720 : 0xffffff801275c9d0
0xffffff82f5ffb740 : 0xffffff80127aef97
0xffffff82f5ffb860 : 0xffffff80127aede3
0xffffff82f5ffb8d0 : 0xffffff8012a06ee6
0xffffff82f5ffbb10 : 0xffffff8012a08733
0xffffff82f5ffbf00 : 0xffffff8012a08276
0xffffff82f5ffbf40 : 0xffffff8012db9bfd
0xffffff82f5ffbfa0 : 0xffffff801275d196
It only seems to do it with one disc, the rest are fine so I am assuming it isn't a general problem with the program.
mrdrummond
Post by mrdrummond » Sat Dec 21, 2024 6:40 am
Did you ever figure it out ? my mac does it to.
Post by dcoke22 » Thu Jan 09, 2025 7:05 pm
mrdrummond wrote: Sat Dec 21, 2024 6:40 am Did you ever figure it out ? my mac does it to.
Is MakeMKV crashing on a specific disc? Perhaps your Mac is having a kernel panic and restarting?
mrdrummond
Post by mrdrummond » Sat Jan 25, 2025 9:42 am
i suspect the external ssd and the external rip drive are pulling too much current from the usb bus.
