Dump File Submitted MKB20_v76_Elf_35E3 **ELF**
mhartsel
#1 Post by mhartsel » Fri Dec 20, 2024 8:00 pm
Dump file submitted MKB20_v76_Elf_35E3
Elf
Re: Dump File Submitted MKB20_v76_Elf_35E3 **ELF**
#2 Post by SamuriHL » Fri Dec 20, 2024 9:26 pm
That dump file doesn't look right.
EDIT: Doesn't seem to matter. Looks like that title is in the keydb.cfg file. Grab the latest, extract it, and copy it to your MakeMKV folder that your tgz file is created in. Restart MakeMKV and you should be good to go.
mhartsel
#3 Post by mhartsel » Sat Dec 21, 2024 12:02 am
Ok, sorry about the double post. Thought something glitched on my end. I did download the file to that directory, but it didn't work. I will try it again here shortly. I will download the file again. Thank you
