Ripping INCEPTION (CN)
OaSys
Post by OaSys » Fri Dec 20, 2024 11:13 am
Apology for my potential mistake in English first.
This is my first time to rip our local release of uhd disc. It went horribly tough. I'm using BU50N to rip. This is the log in decrypting
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=A95C0B8B199B)
Backing up disc into folder "E:/INCEPTION/INCEPTION/INCEPTION"
Failed to save title /BDMV/STREAM/00000.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00000.m2ts
Failed to save title /BDMV/STREAM/00001.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00001.m2ts
Failed to save title /BDMV/STREAM/00002.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00002.m2ts
Failed to save title /BDMV/STREAM/00003.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00003.m2ts
Failed to save title /BDMV/STREAM/00004.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00004.m2ts
Failed to save title /BDMV/STREAM/00005.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00005.m2ts
Hash check failed for file 00006.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00006.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00006.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00006.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00006.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00006.m2ts.
Hash check for /BDMV/STREAM/00006.m2ts : 99.93% corrupt, 0% correct, 99.93% checked.
Failed to save title /BDMV/STREAM/00007.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00007.m2ts
Failed to save title /BDMV/STREAM/00009.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00009.m2ts
Failed to save title /BDMV/STREAM/00010.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00010.m2ts
Failed to save title /BDMV/STREAM/00012.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00012.m2ts
Failed to save title /BDMV/STREAM/00013.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00013.m2ts
Failed to save title /BDMV/STREAM/00014.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00014.m2ts
Failed to save title /BDMV/STREAM/00015.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00015.m2ts
Failed to save title /BDMV/STREAM/00059.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00059.m2ts
Failed to save title /BDMV/STREAM/00060.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00060.m2ts
Failed to save title /BDMV/STREAM/00063.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00063.m2ts
Failed to save title /BDMV/STREAM/00901.m2ts to file E:/INCEPTION/INCEPTION/INCEPTION/BDMV/STREAM/00901.m2ts
Hash check failed for file 00011.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00011.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00011.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00011.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00011.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00011.m2ts.
Hash check for /BDMV/STREAM/00011.m2ts : 99.97% corrupt, 0% correct, 99.97% checked.
I've searched at forum, most said that something wrong with the disc/driver. Not meant to doubt them but I didn't find a post has the same question like mine. I check the way in no-decryption too.
Backing up disc into folder "E:/INCEPTION/INCEPTION"
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom1'
Hash check failed for file 00001.m2ts at offset 190464, file is corrupt.
Hash check for /BDMV/STREAM/00001.m2ts : 88.88% corrupt, 0% correct, 88.88% checked.
Hash check failed for file 00002.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00002.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00002.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00002.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00002.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00002.m2ts.
Hash check for /BDMV/STREAM/00002.m2ts : 99.68% corrupt, 0% correct, 99.68% checked.
Hash check failed for file 00003.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00003.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00003.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00003.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00003.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00003.m2ts.
Hash check for /BDMV/STREAM/00003.m2ts : 100% corrupt, 0% correct, 100% checked.
Hash check failed for file 00004.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00004.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00004.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00004.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00004.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00004.m2ts.
Hash check for /BDMV/STREAM/00004.m2ts : 99.86% corrupt, 0% correct, 99.86% checked.
Hash check failed for file 00005.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00005.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00005.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00005.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00005.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00005.m2ts.
Hash check for /BDMV/STREAM/00005.m2ts : 98.24% corrupt, 0% correct, 98.24% checked.
Hash check failed for file 00007.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00007.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00007.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00007.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00007.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00007.m2ts.
Hash check for /BDMV/STREAM/00007.m2ts : 96.07% corrupt, 0% correct, 96.07% checked.
Hash check failed for file 00009.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00009.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00009.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00009.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00009.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00009.m2ts.
Hash check for /BDMV/STREAM/00009.m2ts : 91.42% corrupt, 0% correct, 91.42% checked.
Hash check failed for file 00012.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00012.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00012.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00012.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00012.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00012.m2ts.
Hash check for /BDMV/STREAM/00012.m2ts : 99.80% corrupt, 0% correct, 99.80% checked.
Hash check failed for file 00013.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00013.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00013.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00013.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00013.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00013.m2ts.
Hash check for /BDMV/STREAM/00063.m2ts : 89.30% corrupt, 0% correct, 89.30% checked.
The thing I suspected is that every m2ts file failed the hashcheck in 0% correct. But the file except movie part is still viewable (at least not 0% correct). Is that anything related to the hashkey? If not, how could I check which part went wrong? Consider to my own situation, Whole exchange of playback system would be desperate...
Re: Ripping INCEPTION (CN)
Post by dcoke22 » Fri Dec 20, 2024 11:05 pm
Is your drive flashed to support LibreDrive? Can you post your MakeMKV drive info (from the first screen of MakeMKV)?
OaSys
Post by OaSys » Sat Dec 21, 2024 7:56 am
dcoke22 wrote: Fri Dec 20, 2024 11:05 pm Is your drive flashed to support LibreDrive? Can you post your MakeMKV drive info (from the first screen of MakeMKV)?
Certainly. Flashed it about two years ago.
Post by dcoke22 » Tue Dec 24, 2024 3:51 am
A hash check failure generally means the drive could not ready a spot on the disc properly. The standard advice is the gently clean the disc and try again.
I don't have a lot of experience with a key exchange failure. I suppose it might mean the drive isn't getting enough power and is 'rebooting' in the middle of a rip.
OaSys
Post by OaSys » Tue Dec 24, 2024 1:14 pm
dcoke22 wrote: Tue Dec 24, 2024 3:51 am A hash check failure generally means the drive could not ready a spot on the disc properly. The standard advice is the gently clean the disc and try again.
I do using external drive through a box to a laptop usb and it had a halt before ripping the main film.
Thanks for helping. I'll try another box.
OaSys
Post by OaSys » Wed Sep 03, 2025 6:39 pm
I just forgot to end this post
Already solved, discs not cleaned and driver is not fully powered.
And use pioneer as your best opinion...
