Is my pioneer BDR-XD05s flashable?
jibanyanlnewells
Post by jibanyanlnewells »
Hello! I have a Pioneer BDR-XD05S (the S shows up on the sticker on the bottom) that was manufactured in january of 2017 (according to the sticker on the bottom) and I was wondering if it was possible to have flashed to work with UHD discs? The drive and libredrive information are as follows:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Firmware date: 2014-12-26
Highest AACS version: 76
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
Re: Is my pioneer BDR-XD05s flashable?
jibanyanlnewells wrote: Thu Dec 12, 2024 7:40 pm Hello! I have a Pioneer BDR-XD05S (the S shows up on the sticker on the bottom) that was manufactured in january of 2017 (according to the sticker on the bottom) and I was wondering if it was possible to have flashed to work with UHD discs? The drive and libredrive information are as follows:
Revision: 3.01
PM sent.
jibanyanlnewells
Coopervid wrote: Fri Dec 13, 2024 10:27 am
Revision: 3.01
PM sent.
Sorry if this comes off as rude, I am new to this forum. but I don't see any private messages in my inbox?
jibanyanlnewells wrote: Fri Dec 13, 2024 3:22 pm
Revision: 3.01
PM sent.
Resent. Something must have gone wrong.
macdev
Post by macdev »
Good day, all.
I came here to check if there was another drive I could buy since my Asus grinds its gears on a few discs once in a while (but very rarely). I have a Pioneer BDR-XD05S also and took a shot to see if this was flashable and found this thread. Any help? Thanks.
Revision: 3.01
Serial number: REMOVED
Highest AACS version: 68
macdev wrote: Fri Dec 20, 2024 4:51 pm Good day, all.
Revision: 3.01
PM is coming. You need a Windows PC to make it work.
macdev
Post by macdev »
Thanks, I have Windows. I'll let you know how it goes.
macdev
Post by macdev »
It worked!! Thanks so much!
F1nkNasty
Post by F1nkNasty »
Does anyone happen to have any more information on how to flash the firmware on this drive? I just happened to stumble across this form while Googling if my drive was 4K capable.
I just created an account to see if anyone had any more information on this.
The important part is what your drive's BIOS says about its software. If it was flashed recently, it may be locked out. That's why posting your drive information is important.
F1nkNasty
Post by F1nkNasty »
Woodstock wrote: Wed Jan 01, 2025 5:32 pm The important part is what your drive's BIOS says about its software. If it was flashed recently, it may be locked out. That's why posting your drive information is important.
Sorry about that, my drive information is below.
Revision: 3.01
Serial number: ...
Took a while... Read your PM:
RB2049
Post by RB2049 »
I was wondering if my drive would also be flashable
Drive informatie
Naam OS-apparaat: \Device\CdRom1
Huidig profiel: BD-R SRM
Fabrikant: PIONEER
Revisie: 3.01
Serienummer: ...
Firmware datum: 2014-12-26
Bus encryptie flags: 1B
Highest AACS version: 77
And on a sidenote, I have another Pioneer drive that does not seem to read blu ray's but it might be able to?
That would be the following drive
Drive informatie
Naam OS-apparaat: G:
Fabrikant: PIONEER
Product: BDW-PR1EPDVPP100
Revisie: 1.01
Serienummer: ...
Firmware datum: 2018-03-06
Drive platform: Pioneer RS8680
Firmware version: ID79
Edit:
Ps: apologies for the direct question(s). I haven’t looked here in ages and saw this post and jumped on the opportunity to ask the question.
Greetings all!
RB2049 wrote: Sat Jan 04, 2025 8:51 pm I was wondering if my drive would also be flashable
Drive informatie
Fabrikant: PIONEER
Revisie: 3.01
Serienummer: ...
Drive informatie
Fabrikant: PIONEER
Revisie: 1.01
Serienummer: ...
Edit:
Greetings all!
PM sent.
vtedogs
Post by vtedogs »
Is mine flashable ?
Revision: 3.10
Serial number: ..
Firmware date: 2017-06-22
Drive platform: RS8232
Firmware version: 3.10/ID34
