Pioneer BDR-UD03 UHD possibility
badeldibub
Re: Pioneer BDR-UD03 UHD possibility
Thank you, again. Hadn't used the first one yet.
This thread is very promising! Any chance you can send me a firmware for my drive that I accidentally updated a long time ago?
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: ...
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: ID05
Revision: 1.03
Serial number: ...
metadragon
I'm in:
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Revision: 1.14
Serial number: ...
Too late - the firmware is already screwed up, locked by Pioneer to prevent use for UHDs.Firmware date: 2023-01-06
PM sent.metadragon wrote: Thu Dec 19, 2024 8:42 pm I'm in:
Revision: 1.14
Serial number: ...
woodputtie
Hey Thanks! It's working perfect. I thought I was out of luck. Thanks a tonn!Coopervid wrote: Thu Dec 19, 2024 1:26 pmPM sent.woodputtie wrote: Thu Dec 19, 2024 12:07 am Hey I just got the same drive in today. Here's the info:
OS device name: G:
Revision: 1.03
Serial number:
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
Disc Information
Disc is being loaded
metadragon
Worked like a charm, much appreciated!Coopervid wrote: Thu Dec 19, 2024 10:17 pmPM sent.metadragon wrote: Thu Dec 19, 2024 8:42 pm I'm in:
Revision: 1.14
Serial number: ...
Aflutter8838
Can you please send me the info as well? I have the same drive.
Current profile: CD-ROM
Revision: 1.14
Serial number: ...
Revision: 1.14
Serial number: ...
PM is coming.Aflutter8838 wrote: Fri Dec 20, 2024 8:03 pm Can you please send me the info as well? I have the same drive.
Revision: 1.14
Serial number: ...
Aflutter8838
The rip went well, with one issue there is no sound. I selected the sound format I wanted, and left everything to default. There weren't any errors in the output status. Any assistance would be appreciated. Here's the sound format I selected for output:
Track information
Type: Audio
Name: Surround 7.1 (English)
Language: English
Codec: TrueHD Atmos
Channels: 8
Channel layout: 7.1
Sample rate: 48000
Bits per sample: 24
MKV Flags: Default
Track information
Type: Audio
Language: English
Codec: TrueHD Atmos
Channels: 8
Channel layout: 7.1
Sample rate: 48000
Bits per sample: 24
MKV Flags: Default
Provide the mkv output from Media info so we can see exactly what is in the resulting mkv file.Aflutter8838 wrote: Sat Dec 21, 2024 3:02 pm The rip went well, with one issue there is no sound. I selected the sound format I wanted, and left everything to default. There weren't any errors in the output status. Any assistance would be appreciated. Here's the sound format I selected for output:
Track information
Type: Audio
Language: English
Codec: TrueHD Atmos
Channels: 8
Channel layout: 7.1
Sample rate: 48000
Bits per sample: 24
MKV Flags: Default
You may be missing some audio codecs on your PC.
Aflutter8838
That as exactly it. I had to use a different video player and then I was able to hear the sound. Windows media player I guess doesn't have the codec to properly play .mkv files. Thanks for your help.
No, Windows Media Player doesn't have the audio codecs to play TrueHD (Atmos).Aflutter8838 wrote: Sun Dec 22, 2024 1:56 am That as exactly it. I had to use a different video player and then I was able to hear the sound. Windows media player I guess doesn't have the codec to properly play .mkv files. Thanks for your help.
Try to download MPC-HC Player... and dont forget to also download the K-Lite Codec Pack to add on more Codec's. it works hand in hand to provide all u need player.
