Pioneer BDR-UD03 UHD possibility
badeldibub
Re: Pioneer BDR-UD03 UHD possibility
Post by badeldibub »
Thank you, again. Hadn't used the first one yet.
Mav'rick
Post by Mav'rick »
This thread is very promising! Any chance you can send me a firmware for my drive that I accidentally updated a long time ago?
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: ...
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: ID05
metadragon
Post by metadragon »
I'm in:
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Too late - the firmware is already screwed up, locked by Pioneer to prevent use for UHDs.
metadragon wrote: Thu Dec 19, 2024 8:42 pm I'm in:
Revision: 1.14
Serial number: ...
PM sent.
woodputtie
Post by woodputtie »
Coopervid wrote: Thu Dec 19, 2024 1:26 pm
woodputtie wrote: Thu Dec 19, 2024 12:07 am Hey I just got the same drive in today. Here's the info:
OS device name: G:
Revision: 1.03
Serial number:
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
Disc Information
Disc is being loaded
PM sent.
Hey Thanks! It's working perfect. I thought I was out of luck. Thanks a tonn!
metadragon
Coopervid wrote: Thu Dec 19, 2024 10:17 pm
Revision: 1.14
Serial number: ...
PM sent.
Worked like a charm, much appreciated!
Aflutter8838
Post by Aflutter8838 »
Can you please send me the info as well? I have the same drive.
Current profile: CD-ROM
Revision: 1.14
Serial number: ...
Aflutter8838 wrote: Fri Dec 20, 2024 8:03 pm Can you please send me the info as well? I have the same drive.
Revision: 1.14
Serial number: ...
PM is coming.
Aflutter8838
The rip went well, with one issue there is no sound. I selected the sound format I wanted, and left everything to default. There weren't any errors in the output status. Any assistance would be appreciated. Here's the sound format I selected for output:
Track information
Type: Audio
Name: Surround 7.1 (English)
Language: English
Codec: TrueHD Atmos
Channels: 8
Channel layout: 7.1
Sample rate: 48000
Bits per sample: 24
MKV Flags: Default
Aflutter8838 wrote: Sat Dec 21, 2024 3:02 pm The rip went well, with one issue there is no sound. I selected the sound format I wanted, and left everything to default. There weren't any errors in the output status. Any assistance would be appreciated. Here's the sound format I selected for output:
Track information
Type: Audio
Language: English
Codec: TrueHD Atmos
Channels: 8
Channel layout: 7.1
Sample rate: 48000
Bits per sample: 24
MKV Flags: Default
Provide the mkv output from Media info so we can see exactly what is in the resulting mkv file.
You may be missing some audio codecs on your PC.
Aflutter8838
That as exactly it. I had to use a different video player and then I was able to hear the sound. Windows media player I guess doesn't have the codec to properly play .mkv files. Thanks for your help.
Aflutter8838 wrote: Sun Dec 22, 2024 1:56 am That as exactly it. I had to use a different video player and then I was able to hear the sound. Windows media player I guess doesn't have the codec to properly play .mkv files. Thanks for your help.
No, Windows Media Player doesn't have the audio codecs to play TrueHD (Atmos).
Yethidran
Post by Yethidran »
Try to download MPC-HC Player... and dont forget to also download the K-Lite Codec Pack to add on more Codec's. it works hand in hand to provide all u need player.
