Pioneer BDR-UD03 UHD possibility
badeldibub
Re: Pioneer BDR-UD03 UHD possibility
#436 Post by badeldibub » Thu Dec 19, 2024 1:53 pm
Thank you, again. Hadn't used the first one yet.
Mav'rick
#437 Post by Mav'rick » Thu Dec 19, 2024 5:43 pm
This thread is very promising! Any chance you can send me a firmware for my drive that I accidentally updated a long time ago?
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: ...
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: ID05
metadragon
#438 Post by metadragon » Thu Dec 19, 2024 8:42 pm
I'm in:
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
#439 Post by Woodstock » Thu Dec 19, 2024 9:16 pm
Too late - the firmware is already screwed up, locked by Pioneer to prevent use for UHDs.
#440 Post by Coopervid » Thu Dec 19, 2024 10:17 pm
metadragon wrote: Thu Dec 19, 2024 8:42 pm I'm in:
Revision: 1.14
Serial number: ...
PM sent.
woodputtie
#441 Post by woodputtie » Thu Dec 19, 2024 11:30 pm
Coopervid wrote: Thu Dec 19, 2024 1:26 pm
woodputtie wrote: Thu Dec 19, 2024 12:07 am Hey I just got the same drive in today. Here's the info:
OS device name: G:
Revision: 1.03
Serial number:
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
Disc Information
Disc is being loaded
PM sent.
Hey Thanks! It's working perfect. I thought I was out of luck. Thanks a tonn!
metadragon
#442 Post by metadragon » Fri Dec 20, 2024 3:57 am
Coopervid wrote: Thu Dec 19, 2024 10:17 pm
Revision: 1.14
Serial number: ...
PM sent.
Worked like a charm, much appreciated!
Aflutter8838
#443 Post by Aflutter8838 » Fri Dec 20, 2024 8:03 pm
Can you please send me the info as well? I have the same drive.
Current profile: CD-ROM
Revision: 1.14
Serial number: ...
#444 Post by Coopervid » Fri Dec 20, 2024 9:26 pm
Aflutter8838 wrote: Fri Dec 20, 2024 8:03 pm Can you please send me the info as well? I have the same drive.
Revision: 1.14
Serial number: ...
PM is coming.
Aflutter8838
#445 Post by Aflutter8838 » Sat Dec 21, 2024 3:02 pm
The rip went well, with one issue there is no sound. I selected the sound format I wanted, and left everything to default. There weren't any errors in the output status. Any assistance would be appreciated. Here's the sound format I selected for output:
Track information
Type: Audio
Name: Surround 7.1 (English)
Language: English
Codec: TrueHD Atmos
Channels: 8
Channel layout: 7.1
Sample rate: 48000
Bits per sample: 24
MKV Flags: Default
#446 Post by MartyMcNuts » Sat Dec 21, 2024 8:59 pm
Aflutter8838 wrote: Sat Dec 21, 2024 3:02 pm The rip went well, with one issue there is no sound. I selected the sound format I wanted, and left everything to default. There weren't any errors in the output status. Any assistance would be appreciated. Here's the sound format I selected for output:
Track information
Type: Audio
Language: English
Codec: TrueHD Atmos
Channels: 8
Channel layout: 7.1
Sample rate: 48000
Bits per sample: 24
MKV Flags: Default
Provide the mkv output from Media info so we can see exactly what is in the resulting mkv file.
You may be missing some audio codecs on your PC.
Aflutter8838
#447 Post by Aflutter8838 » Sun Dec 22, 2024 1:56 am
That as exactly it. I had to use a different video player and then I was able to hear the sound. Windows media player I guess doesn't have the codec to properly play .mkv files. Thanks for your help.
#448 Post by MartyMcNuts » Sun Dec 22, 2024 3:54 am
Aflutter8838 wrote: Sun Dec 22, 2024 1:56 am That as exactly it. I had to use a different video player and then I was able to hear the sound. Windows media player I guess doesn't have the codec to properly play .mkv files. Thanks for your help.
No, Windows Media Player doesn't have the audio codecs to play TrueHD (Atmos).
Yethidran
#449 Post by Yethidran » Sun Dec 22, 2024 4:48 am
Try to download MPC-HC Player... and dont forget to also download the K-Lite Codec Pack to add on more Codec's. it works hand in hand to provide all u need player.
Yethidran
#450 Post by Yethidran » Sun Dec 22, 2024 4:50 am
