MakeMKV doesn't open many MKV files
ryanjk333
Post by ryanjk333 »
I want to quickly comment on what a great program MakeMKV is. It works great and I'll be buying the final product for sure!
Anyway, I know that the program is also supposed to be able to open MKV files so that certain tracks can be checked/unchecked and a new MKV file muxed from those choices. However, when I open an MKV file originally created by basically any program other than MakeMKV, I get the following errors in the MakeMKV error log:
Debug log started at Mon Oct 24 21:43:08 2011 , written by MakeMKV v1.6.15 win(x64-release)
001005:0000 MakeMKV v1.6.15 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Ryan/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at 51r3,ZHr1#T/_s~&J1\+:121269041
001003:0020 DEBUG: Code 0 at TM2G`"NgKk0!<wrnLz:121261681
001003:0020 DEBUG: Code 0 at TM2G`"NgKk0!<wrnLz:213130191
005043:0000 Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
001003:0020 DEBUG: Code 0 at +%V4CJY/GW7w_Iq7:213130352
001003:0020 DEBUG: Code 0 at rEoMm/'^zJA=Y$l:29396713
001003:0020 DEBUG: Code 0 at ag8I?#>JyGw%X0V7g:213130467
Application exited at Mon Oct 24 21:44:16 2011
Does anyone know why MakeMKV doesn't like to open MKV files that it itself didn't create? Is there a future fix for this problem? Thanks much!
MakeMKV registered!
LG External 12x Super Multi Blue Lightscribe Blu-Ray Rewriter BE12LU30
Popcorn Hour C-200
Re: MakeMKV doesn't open many MKV files
Post by mike admin »
MakeMKV is supposed to open any MKV file, created by any application, even with options that it would never set by itself; providing it knows all codecs that are inside such MKV file. In practice that means that video should be mpeg2, mpeg-4 or VC-1 and audio/subs in any format that could possibly be present on DVD,HD-DVD or blu-ray.
In your particular case it chocked on incompatible H.264 stream that seems to be a big in MakeMKV.
Please open your MKV file in mkvmerge, cut it to be about 10 seconds long, upload to mediafire or dropbox and send the link to support@makemkv.com .
Thank you.
ryanjk333
Post by ryanjk333 »
Thanks for your response, Mike! I have emailed you a 10 second clip. Hopefully it'll be an easy fix!
MakeMKV registered!
Popcorn Hour C-200
