Hi there
I have the following unit:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: BDDXXXXXWL
Firmware date: 2020-06-15
Highest AACS version: 76
Drive platform: RS8511
Firmware version: 1.14
Do I need to do something in particular to have it up and running?
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
PM sent but you need to attach your drive to a Windows computer for it. Hope you will find one.CofDiv wrote: Sun Dec 15, 2024 2:04 pmHere it is:
CD location : /dev/sr0
CD driver name: GNU/Linux
access mode: IOCTL
Vendor : PIONEER
Model : BD-RW BDR-UD03
Revision : 1.14
Hardware : CD-ROM or DVD
Can eject : Yes
Can close tray : Yes
Can disable manual eject : Yes
Can select juke-box disc : No
Can set drive speed : No
Can read multiple sessions (e.g. PhotoCD) : Yes
Can hard reset device : Yes
Reading....
Can read Mode 2 Form 1 : Yes
Can read Mode 2 Form 2 : Yes
Can read (S)VCD (i.e. Mode 2 Form 1/2) : Yes
Can read C2 Errors : No
Can read IRSC : Yes
Can read Media Channel Number (or UPC) : Yes
Can play audio : Yes
Can read CD-DA : Yes
Can read CD-R : Yes
Can read CD-RW : Yes
Can read DVD-ROM : Yes
Writing....
Can write CD-RW : Yes
Can write DVD-R : Yes
Can write DVD-RAM : Yes
Can write DVD-RW : No
Can write DVD+RW : No
__________________________________
Yes. Read your PM.Felpollo wrote: Sun Dec 15, 2024 4:45 pm Hi there
Revision: 1.14
PixelBits
Coopervid wrote: Tue Sep 17, 2024 3:37 pmPM sent. Read carefully and do it step by step.PixelBits wrote: Sun Sep 15, 2024 9:56 am Hi all,
I found this website/forum doing some googling about my USB Pioneer BD-RW Drive.
I have a Pioneer BD-RW BDR-UD03D [ extra character 'D' in product id ] and cant find that much regarding this particular drive, makeMKV only shows limited info about the hardware. Does anyone know if this is compatible/moddable for UHD media.
OS device name: U:
Product: BD-RW BDR-UD03D
Revision: 1.00
Serial number: [redacted]
Highest AACS version: 14
many thanks in advance.![]()
It took abit of time but got the drive working perfectly with your info and firmware. Initially thought it failed but it was a USB power issue that stopped it working properly (it just stopped reading discs properly) after firmware update. Connected the drive to a higher power USB-C with an adaptor and the drive now rips like a champ
Yes. The Verbatim enclosure is very power hungry. That is well known.
CofDiv
Coopervid wrote: Sun Dec 15, 2024 7:24 pmPM sent but you need to attach your drive to a Windows computer for it. Hope you will find one.CofDiv wrote: Sun Dec 15, 2024 2:04 pmHere it is:
access mode: IOCTL
Vendor : PIONEER
Revision : 1.14
Can eject : Yes
Reading....
Can read IRSC : Yes
Can read CD-R : Yes
Writing....
I have an old Windows notebook for such things. Flashing is very easy and worked without any problem.
Thanks a lot
D9M2W
Can I please jump in the train, I am in the same boat
badeldibub
Hello
I have this drive, too. (Labelled as Verbatim)
Could I get some help, too? Thanks a lot!!
OS device name: E:
Revision: 1.14
Serial number: [...]
Unrestricted read speed: Yes-
Post your Makemkv info.
woodputtie
Hey I just got the same drive in today. Here's the info:
OS device name: G:
Revision: 1.03
Serial number:
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
Disc Information
Disc is being loaded
OS device name: G:
Revision: 1.03
Serial number:
Disc Information
mululuna
Same deal here with a verbatim drive, would like to use for uhd rip
OS device name: F:
Revision: 1.14
Serial number: ...
OS device name: F:
Revision: 1.14
Serial number: ...
PM sent.badeldibub wrote: Wed Dec 18, 2024 9:21 pm Hello
Could I get some help, too? Thanks a lot!!Code: Select all
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: [...] Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
PM sent.woodputtie wrote: Thu Dec 19, 2024 12:07 am Hey I just got the same drive in today. Here's the info:
OS device name: G:
Revision: 1.03
Serial number:
Disc Information
badeldibub
Thank you!
Check your PM again. Wrong link in my last PM!badeldibub wrote: Wed Dec 18, 2024 9:21 pm Hello
