Need help very new to this
Richard3000
#1 Post by Richard3000 » Wed Dec 18, 2024 11:47 pm
Hello I need help I’m very new to this but I keep getting this error on a blu ray disc that used to work and I have no idea why
This is the error
Error 'OS error - The 1/0 device reported an I/O error' occurred while reading "\Device\CdRom 1' at offset '2164322304'
DEBUG: Code 3221225861 at T*66ml"9R%2H1-6CT:213131502
Does anyone know why ?
Re: Need help very new to this
#2 Post by Woodstock » Thu Dec 19, 2024 1:06 am
The error is much like the errors seen when a disk is spun faster than it has power to spin. Is this a USB drive?
Richard3000
#3 Post by Richard3000 » Thu Dec 19, 2024 5:58 am
Yes it is
Richard3000
#4 Post by Richard3000 » Thu Dec 19, 2024 6:00 am
Would getting a usb hub help to power the drive
#5 Post by Woodstock » Thu Dec 19, 2024 1:56 pm
It depends on the drive. Most that were cabled for USB1 or 2 hubs have a two-head cable. Both need to be plugged into independently-powered ports (usually on your computer, not on a "passive hub" without a power supply). If the hub HAS a power supply, you can plug both into it and it should work.
If the drive was intended for a USB3 port (which has better power reserves), then making sure you're plugged into a "blue port" should work.
Another alternative is to limit how fast the drive can spin, so it doesn't use too much power. That's usually done by making MakeMKV write to slower media, but that's a pain to do.
