Pioneer BDR-UD03 UHD possibility
Felpollo
Re: Pioneer BDR-UD03 UHD possibility
#421 Post by Felpollo » Sun Dec 15, 2024 4:45 pm
Hi there
I have the following unit:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: BDDXXXXXWL
Firmware date: 2020-06-15
Highest AACS version: 76
Drive platform: RS8511
Firmware version: 1.14
Do I need to do something in particular to have it up and running?
#422 Post by Coopervid » Sun Dec 15, 2024 7:24 pm
CofDiv wrote: Sun Dec 15, 2024 2:04 pm
Coopervid wrote: Fri Dec 13, 2024 8:06 pm
CofDiv wrote: Fri Dec 13, 2024 3:23 pm I have also the same problem with my BDR-UD03. Please need help :mrgreen:
Post your Makemkv info.
Here it is:
CD location : /dev/sr0
CD driver name: GNU/Linux
access mode: IOCTL
Vendor : PIONEER
Model : BD-RW BDR-UD03
Revision : 1.14
Hardware : CD-ROM or DVD
Can eject : Yes
Can close tray : Yes
Can disable manual eject : Yes
Can select juke-box disc : No
Can set drive speed : No
Can read multiple sessions (e.g. PhotoCD) : Yes
Can hard reset device : Yes
Reading....
Can read Mode 2 Form 1 : Yes
Can read Mode 2 Form 2 : Yes
Can read (S)VCD (i.e. Mode 2 Form 1/2) : Yes
Can read C2 Errors : No
Can read IRSC : Yes
Can read Media Channel Number (or UPC) : Yes
Can play audio : Yes
Can read CD-DA : Yes
Can read CD-R : Yes
Can read CD-RW : Yes
Can read DVD-ROM : Yes
Writing....
Can write CD-RW : Yes
Can write DVD-R : Yes
Can write DVD-RAM : Yes
Can write DVD-RW : No
Can write DVD+RW : No
__________________________________
PM sent but you need to attach your drive to a Windows computer for it. Hope you will find one.
#423 Post by Coopervid » Sun Dec 15, 2024 7:27 pm
Felpollo wrote: Sun Dec 15, 2024 4:45 pm Hi there
Revision: 1.14
Yes. Read your PM.
PixelBits
#424 Post by PixelBits » Mon Dec 16, 2024 3:22 am
Coopervid wrote: Tue Sep 17, 2024 3:37 pm
PixelBits wrote: Sun Sep 15, 2024 9:56 am Hi all,
I found this website/forum doing some googling about my USB Pioneer BD-RW Drive.
I have a Pioneer BD-RW BDR-UD03D [ extra character 'D' in product id ] and cant find that much regarding this particular drive, makeMKV only shows limited info about the hardware. Does anyone know if this is compatible/moddable for UHD media.
OS device name: U:
Product: BD-RW BDR-UD03D
Revision: 1.00
Serial number: [redacted]
Highest AACS version: 14
many thanks in advance. 8)
PM sent. Read carefully and do it step by step.
:D Thank you so much and sorry for the late reply.
It took abit of time but got the drive working perfectly with your info and firmware. Initially thought it failed but it was a USB power issue that stopped it working properly (it just stopped reading discs properly) after firmware update. Connected the drive to a higher power USB-C with an adaptor and the drive now rips like a champ :D :D
#425 Post by Coopervid » Mon Dec 16, 2024 11:56 am
Yes. The Verbatim enclosure is very power hungry. That is well known.
CofDiv
#426 Post by CofDiv » Tue Dec 17, 2024 8:50 am
Coopervid wrote: Sun Dec 15, 2024 7:24 pm
Here it is:
access mode: IOCTL
Vendor : PIONEER
Revision : 1.14
Can eject : Yes
Reading....
Can read IRSC : Yes
Can read CD-R : Yes
Writing....
I have an old Windows notebook for such things. Flashing is very easy and worked without any problem.
Thanks a lot
D9M2W
#427 Post by D9M2W » Wed Dec 18, 2024 7:50 pm
Can I please jump in the train, I am in the same boat
badeldibub
#428 Post by badeldibub » Wed Dec 18, 2024 9:21 pm
Hello
I have this drive, too. (Labelled as Verbatim)
OS device name: E:
Revision: 1.14
Serial number: [...]
Could I get some help, too? Thanks a lot!!
#429 Post by Coopervid » Wed Dec 18, 2024 9:26 pm
D9M2W wrote: Wed Dec 18, 2024 7:50 pm Can I please jump in the train, I am in the same boat
woodputtie
#430 Post by woodputtie » Thu Dec 19, 2024 12:07 am
Hey I just got the same drive in today. Here's the info:
OS device name: G:
Revision: 1.03
Serial number:
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
Disc Information
Disc is being loaded
mululuna
#431 Post by mululuna » Thu Dec 19, 2024 6:25 am
Same deal here with a verbatim drive, would like to use for uhd rip
OS device name: F:
Revision: 1.14
Serial number: ...
#432 Post by Coopervid » Thu Dec 19, 2024 1:24 pm
badeldibub wrote: Wed Dec 18, 2024 9:21 pm Hello
OS device name: E:
Revision: 1.14
PM sent.
#433 Post by Coopervid » Thu Dec 19, 2024 1:26 pm
woodputtie wrote: Thu Dec 19, 2024 12:07 am Hey I just got the same drive in today. Here's the info:
OS device name: G:
Revision: 1.03
Serial number:
Disc Information
PM sent.
badeldibub
#434 Post by badeldibub » Thu Dec 19, 2024 1:28 pm
Coopervid wrote: Thu Dec 19, 2024 1:24 pm PM sent.
Thank you!
#435 Post by Coopervid » Thu Dec 19, 2024 1:30 pm
OS device name: E:
Revision: 1.14
Check your PM again. Wrong link in my last PM!
