I've been trying to rip The Last Jedi (4K) for about a week now) Could anybody help me with this?
This is the error message I'm getting: AV sync issue in stream 1 at 0:00:00 with duration of 0.666ms : encountered overlapping frame, audio skew is +0.666ms
Product: BD-RE BU40N
Revision: 1.03
Serial number: [redacted]
Highest AACS version: 77
Firmware version: 1.03
Disc Information
Label: THE_LAST_JEDI
Timestamp: 2018-01-29 16:18:36
Protection: AACS2.0/C v61
Data capacity: 61.88 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Archegon Drive not ripping
Re: Archegon Drive not ripping
At the end of the rip, does the message say the file was written? You're listing a message that usually indicates a correction was made to a timing issue on the disk, not a error message as in "the rip failed!!!!"
