LibreDrive for Pioneer drives
EARTHQUAKEMAN
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.21
Serial number: CADL666978WL
Firmware date: 2018-04-26
Highest AACS version: 61
Firmware version: ID19
coopervid can you send me the flash file aswell please? thank in advance.
Revision: 1.21
zezba9000
Got a new "BDR-S13UBK" from Amazon recently but it doesn't allow ripping of 4k disks with this firmware version.
Product: BD-RW BDR-S13U
Revision: 1.05
Serial number: DBDL930342UC
Firmware date: 2023-08-01
Highest AACS version: 81
Firmware version: ID43
Nope. Too new. Return it.zezba9000 wrote: Mon Dec 16, 2024 9:18 am Got a new "BDR-S13UBK" from Amazon recently but it doesn't allow ripping of 4k disks with this firmware version.
Revision: 1.05
MissFortuned
Hi all, new to the forum but have been using MakeMKV for a long time to back up my BluRay discs. I'm recently looking into backing up my 4K UHD discs. When I tried to use MakeMKV for a 4K disc, I received this error:
If this drive is no good, could anyone recommend where I could pick up a suitable UHD external drive that would enable me to back up my 4K UHD discs? I'm located in Australia. Thank you in advance for your help.
Here are the details for my Pioneer drive - from everything I've read I believe the firmware date on mine may be too new so I can't use this drive to back up my 4K discs? It works fine for BluRays. I'm not overly knowledgeable in this area but have read everything I can find on this forum.Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0', Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED', Occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive. LibreDrive compatible drive is required to open this disc - video can't be decrypted.
OS device name: E:
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: ---
Firmware date: 2023-01-06
Bus encryption flags: 13
Firmware version: ID05-
yeah sorry it to new i recommend you return it if you can.MissFortuned wrote: Tue Dec 17, 2024 10:28 am Hi all, new to the forum but have been using MakeMKV for a long time to back up my BluRay discs. I'm recently looking into backing up my 4K UHD discs. When I tried to use MakeMKV for a 4K disc, I received this error:Here are the details for my Pioneer drive - from everything I've read I believe the firmware date on mine may be too new so I can't use this drive to back up my 4K discs? It works fine for BluRays. I'm not overly knowledgeable in this area but have read everything I can find on this forum.Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0', Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED', Occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive. LibreDrive compatible drive is required to open this disc - video can't be decrypted.
Drive Information OS device name: E: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XS07U Revision: 1.03 Serial number: --- Firmware date: 2023-01-06 Bus encryption flags: 13 Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8E21 Firmware version: ID05
marty is the guy for Australia here is his post viewtopic.php?f=20&t=18747 and his website https://uhdenableddrives.com/
debtor-swab-fable
Hello. This is my first time using MakeMKV and I can't seem to get it to work. I have attached my log file. I am using the Pioneer BDR-XD08UMB-S. Any help would be appreciated.
Your firmware is too new and encrypted. Return it if you still can.debtor-swab-fable wrote: Wed Dec 18, 2024 1:40 am Hello. This is my first time using MakeMKV and I can't seem to get it to work. I have attached my log file. I am using the Pioneer BDR-XD08UMB-S. Any help would be appreciated.
PM sent.EARTHQUAKEMAN wrote: Mon Dec 16, 2024 6:42 am Drive Information
Revision: 1.21
debtor-swab-fable
Understood. Thank you Coopervid.Coopervid wrote: Wed Dec 18, 2024 10:07 amYour firmware is too new and encrypted. Return it if you still can.debtor-swab-fable wrote: Wed Dec 18, 2024 1:40 am Hello. This is my first time using MakeMKV and I can't seem to get it to work. I have attached my log file. I am using the Pioneer BDR-XD08UMB-S. Any help would be appreciated.
RobC-B
It's fixed!
Billy Carlson advised me how to clean the device lasers and it worked great because the unit immediately recognized the BD-R and did perfect writing.
Thank you so much to the Moderator and especially Billy! ---Rob
I had to reinstall Win11 and something dinged my VinPower (Pioneer BD-212V) which used to work with BluRay Disks.
I need to copy some files to BD-R disks Verbatim16x.
The firmware was (and is still) what VinPower provided and I see that many other folks have had the same setup and are referred for a firmware update but I don't know who to ask for one.
Your help is appreciated. I really like makemkv and have used it a bunch.
Here is drive info:
OS device name: L:
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: AEDL012444WL
Firmware date: 2022-05-31
Firmware version: ID06
Thank you, Rob
PM sent.RobC-B wrote: Thu Dec 19, 2024 6:42 am Hello,
Here is drive info:
OS device name: L:
Revision: 1.02
Thank you, Rob
drknight71
Found a BDR-212UHBK drive for sale and the seller said it has firmware version 1.04. Was wondering is that firmware version too new for Libredrive UHD etc? The newest on Pioneers site is ver 1.05.
Thank you.
Edit: Striked out again. Not compatible according to research. Oh well.
Thank you.
EARTHQUAKEMAN
thank you so much i just got the file on my PM have a great day coopervid.Coopervid wrote: Wed Dec 18, 2024 10:08 amPM sent.EARTHQUAKEMAN wrote: Mon Dec 16, 2024 6:42 am Drive Information
Revision: 1.21
alexander_ac
MakeMKV has stopped reading Blu-ray UHD disks, I updated it's firmware to 1.05 which after reading the first dozen or so pages of this thread maybe the cause. Here are the drive details.
Product: BD-RW BDR-S12U
Revision: 1.05
Serial number: AGDL004972WL
Highest AACS version: 72
Drive platform: Pioneer RS8F01
Any assistance to fix this is appreciated.
Revision: 1.05
yeah sorry man its ruined now after you updated it.alexander_ac wrote: Sun Dec 22, 2024 3:14 am Hi,
Revision: 1.05
i have some pioneers with old fw if you want one
