Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
corral9494
Re: Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
Post by corral9494 »
hi all,
first time poster but not new to makemkv.. i've had this same drive fr awhile and i would also like to get it working w/ uhd.. would someone be willing to help? thank u much in advance
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: <redacted>
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8D30
Firmware version: 1.03
axone wrote: Tue Dec 17, 2024 9:31 pm Hi, I also would like to get the 4k up and running.
my drive infos are the following:
Revision: 1.03
Serial number: [redacted]
PM sent.
axone
Post by axone »
Coopervid wrote: Wed Dec 18, 2024 10:26 am
Revision: 1.03
PM sent.
Works perfectly, thank you very much.
werdiknight
Post by werdiknight »
Hi Coopervid,
same problem here. I'd also like to get 4k going (I actually just now realized I couldn't use them when I already bought some... :( )
Makemkv is installed, here are the drive infos:
OS device name: E:
Revision: 1.03
Serial number: ...
Would you be so kind to also send me your PM? Would be greatly appreciated. :)
werdiknight
After reading more and more into it I first thought I'd just needed the fitting firmware (but didn't know which).... until finally noticing that it wouldn't work anyway. I have a dGPU and AMD CPU which I'm not changing - so unfortunately there is that... :(
werdiknight wrote: Tue Dec 31, 2024 2:45 am After reading more and more into it I first thought I'd just needed the fitting firmware (but didn't know which).... until finally noticing that it wouldn't work anyway. I have a dGPU and AMD CPU which I'm not changing - so unfortunately there is that... :(
WTF you are talking about? All you need is a Windows PC that is not based on ARM.
werdiknight
Coopervid wrote: Tue Dec 31, 2024 9:22 pm
Read this somewhere. I have a Windows PC. Maybe I could just try it?
werdiknight wrote: Wed Jan 01, 2025 3:51 am
You have a typo in your forum name. Should be weirdknight... :D :D . You have a PM. And let me know where you have read that BS you posted above.
werdiknight
I'm very sorry... I am ABSOLUTELY new to all of this so I cannot judge what is wrong or what is right from the getgo. And to be honest, it's not the time in my life at the moment to read dozens of hours through a topic I don't know nothing about... soooo, when I read something that COULD be true it may be just that at first glance. It was CyberLink BluRay Advisor (an analytics tool) which told me that my PC like mentioned above is not able to read UHDs, no matter which BD-Player I used.
Thanks for the PM, I may test it these days and let you know of the result. The flashing seemed to have worked but unfortunately I haven't any 4k Discs here anymore to test it right away.
VincentVega
Post by VincentVega »
Hey there,
first-time-poster aswell. Started archieving my BD-Collection several month ago. Everything worked fine till I got to my UHD. After reading in this forum, I bought the following drive with an older firmware, hoping that it would work out of the box. Unfortunatly that is not the case, so I am looking for help :D
Laufwerksinformation
OS-Gerätename: G:
Produzent: PIONEER
Produkt: BD-RW BDR-XD07
Revision: 1.03
Serienummer: ***
Firmware-Datum: 2020-08-20
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 78
Keine Disk eingelegt
galkern
Post by galkern »
Hello Coopervid, I have the following:
Revision: 1.03
Serial number: ...
Is there any way you could help me get UHD working?
VincentVega wrote: Thu Jan 02, 2025 3:24 pm Hey there,
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.03
Serienummer: ***
PM is coming.
galkern wrote: Thu Jan 02, 2025 11:34 pm Hello Coopervid, I have the following:
Revision: 1.03
Serial number: ...
PM is coming.
VincentVega
Works perfectly! Thank you very much, Coopervid :wink:
galkern
Post by galkern »
Coopervid wrote: Fri Jan 03, 2025 5:00 pm
Revision: 1.03
Serial number: ...
PM is coming.
Thank you Coopervid! Worked without a hitch. I even installed it via a Windows 11 vm on Fedora 41, no issues! You rock!
