MakeMKV Blu-ray Rips play fine but makemkv's are choppy ?
Hello.
When I play Adjustment Bureau from the Blu-ray rip foler using Total media 3 I get smooth playback.
When I create an mkv from the rip and play it in TMT3 I get choppy video.
Why is it so?
Also when I look at the rip and mkv using media info I get differing codecs. I thought it should be the same.
Please explain?
The media info output follows for Blu-ray:
users.tpg.com.au/gbung3/abrip.html
Video
Menu ID : 1 (0x1)
Format : VC-1
Format profile : AP@L3
Codec ID : 234
Duration : 1h 45mn
Bit rate : 33.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.676
Stream size : 24.8 GiB (87%)
The media info output follows for MKV:
users.tpg.com.au/gbung3/abmkv.html
Video
Format : VC-1
Codec ID : WVC1
Codec ID/Hint : Microsoft
Duration : 1h 45mn
Bit rate : 32.3 Mbps
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.649
Stream size : 23.8 GiB (93%)
Language : English
Why is it so?
Please explain?
Video
Menu ID : 1 (0x1)
Format : VC-1
Codec ID : 234
Duration : 1h 45mn
Bit depth : 8 bits
Video
Format : VC-1
Codec ID : WVC1
Duration : 1h 45mn
Bit depth : 8 bits
Language : English
Re: MakeMKV Blu-ray Rips play fine but makemkv's are choppy
make sure tmt3 is using dxva codec such as ffdshow tryouts.
I'm interested in why the codec would change between playing the rip and playing the mkv.
TMT3 has awful MKV support.
- Contact:
It's the same codec, VC-1 .gbung wrote:I'm interested in why the codec would change between playing the rip and playing the mkv.
So if the codec is the same why would tmt3 play choppy on mkv but smooth on original rip?
This is only the second movie I've tried. The other one worked fine but it was not vc-1.
TMT handles MKV's very poorly. It's not designed for it.gbung wrote:So if the codec is the same why would tmt3 play choppy on mkv but smooth on original rip?.
TMT5 has far better MKV support FWIW.
sdamaged99
I've got TMT5 and some MKV playback is still atrocious and choppy. It's not down to my CPU or network speed either.
If you want a PC solution for MKV playback, it's hard to beat the following:
MPC-HC
LAV Filters (LAV Audio, LAV Video, LAV Splitter)
madVR
All freeware and/or open source. I use a more advanced player with the LAV Filters and madVR called J River MC16. It has library management capability so that when I rip my BD's to MKV, they are available to any machine on my network. Full bitstreaming and/or decoding (dts-hd ma can be decoded by LAV Audio by using the dtsdecoder.dll from TMT) to PCM. Absolutely awesome.
MPC-HC
madVR
trial of tmt5 has the same issue for me.
Their MKV support in TMT is definitely a work in progress. I'm sure it'll improve over time.
Are your MKVs on a network drive? If so I struggled for a long time trying to understand why my MKV playback was very bad under Windows 7 on a network drive. If I played the content locally it was fine.
The root cause was a setting in Windows 7 that will throttle network performance when multimedia was being played. Unfortunately also throttling the playback of the MKV itself.
The fix is a simple registry change to turn off the network throttling:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile]
"NetworkThrottlingIndex"=dword:ffffffff
After I made this change I've no longer had issues with MKV playback regardless of the player I used.
Vidmo
Vidmo
Interesting. I hadn't seen that value before. Thanks for posting that!
I did a full write up on the MKV playback forum.
http://www.makemkv.com/forum2/viewtopic.php?f=6&t=4208
Vidmo
Vidmo
