Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
Re: Ultimate UHD Drives Flashing Guide Updated 2024
#2581 Post by Coopervid » Thu Dec 12, 2024 6:03 pm
MrMegadeth99 wrote: Thu Dec 12, 2024 5:49 pm No clue I just followed the YouTube video
I see. But that was an example with the file locations on Billy's computer. Your computer had for sure another file location for the .bin files. You should have read the guide here thoroughly and on Windows use SDFToolFlasher which is the easiest way to do it. And you didn't follow the recommendation then what to flash. Call yourself lucky that you didn't screw up your drive regarding everything you did wrong. Fortunately you didn't try to flash a firmware of a slim drive but otherwise somebody can't make almost do more mistakes. In the future please don't do stuff anymore the way you do it.
MrMegadeth99
#2582 Post by MrMegadeth99 » Thu Dec 12, 2024 7:20 pm
I read the guide but I wasn't sure what it all meant. I'm stupid with computer stuff but I did it once before and I did it again. I downloaded the all you need firmware pack and the file for the NS60 was in there and it worked. My drive is the NS40 though so I'm not why I needed the NS60 file. I knew not to flash to a slim drive.
#2583 Post by Coopervid » Thu Dec 12, 2024 7:24 pm
MrMegadeth99 wrote: Thu Dec 12, 2024 7:20 pm I read the guide but I wasn't sure what it all meant. I'm stupid with computer stuff but I did it once before and I did it again. I downloaded the all you need firmware pack and the file for the NS60 was in there and it worked. My drive is the NS40 though so I'm not why I needed the NS60 file. I knew not to flash to a slim drive.
Alright. Ask upfront next time. Better safe than sorry.
jibanyanlnewells
#2584 Post by jibanyanlnewells » Thu Dec 12, 2024 8:37 pm
Hello! I have a Pioneer BDR-XD05S manufactured in january of 2017 that I want to try and get reading UHD blu-rays if possible, is there any way to do that? the drive and libredrive info are as follows:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Firmware date: 2014-12-26
Highest AACS version: 76
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
MrMegadeth99
#2585 Post by MrMegadeth99 » Thu Dec 12, 2024 8:46 pm
Will do thanks
#2586 Post by Coopervid » Thu Dec 12, 2024 9:47 pm
MrMegadeth99 wrote: Thu Dec 12, 2024 8:46 pm Will do thanks
You are welcome. Just be more prudent and cautious in the future. Asking for help upfront is not a weakness but wise.
DharmaBummed
#2587 Post by DharmaBummed » Mon Dec 16, 2024 3:26 am
Thought I'd let people know I was able to successfully flash a LG WH16NS40 with a UGREEN SATA to USB 3.0 Adapter Cable for 3.5 2.5 Inch SSD/HDD Hard Drives. $15.29. Third drive I've flashed now with the SDFTool Flasher. Took just a few minutes. Thank you Billycar11 and MartyMcNuts for making this a super simple process. First 2 drives I flashed were a LG WH14NS40 back in early 2022 flashed to WH16NS60 and a LG BP50NB40 I found a few weeks ago at Best Buy flashed to BU40N. It's nice to be able to watch my UHD discs on my PC now and rip files to use on Plex. I also have a Pioneer BDR-X13UBK I picked up for $12 that just needed the Blu-ray laser lens cleaned. Hopefully someday they'll be able to crack the Pioneer firmware encryption. Even if it never happens I still have a nice Blu-Ray drive/burner for super cheap.
Gedred
#2588 Post by Gedred » Mon Dec 16, 2024 3:10 pm
I recently bought an external Verbatim drive to hopefully play 4k blu ray discs, it didn't work. I have read various threads/posts that discuss friendly UHD drives, and even offer lists!
However having read through various posts it suddenly occurred to me that my current blu ray reader/writer might in itself be suitable.
I have an LG BH 16NS40. No idea what year it is manufactured, as after 2015 seems to be important?
How do I find out? I guess I have to take my machine casing off to look at label/date on my blu ray drive?
Or is there another way of doing this from my pc desktop?
I am not attempting to flash until convinced I won't damage my current player.
Any advice would be appreciated.
#2589 Post by d00zah » Mon Dec 16, 2024 3:34 pm
Gedred wrote: Mon Dec 16, 2024 3:10 pm I recently bought an external Verbatim drive to hopefully play 4k blu ray discs, it didn't work. I have read various threads/posts that discuss friendly UHD drives, and even offer lists!
Copy/paste the MakeMKV Drive Info/LibreDrive Info (right-hand pane) here & someone will be able to advise.
Gedred
#2590 Post by Gedred » Tue Dec 17, 2024 9:51 am
Here is the info related to the blu ray drive.
OS device name: F:
Product: BD-RE BH16NS40
Revision: 1.03
Serial number: [redacted]
Firmware date: 2114-03-26 11:15
Drive platform: MT1939
Firmware version: 1.03
BD raw metadata read: Partial
#2591 Post by Woodstock » Tue Dec 17, 2024 1:40 pm
That hardware won't do UHD.
#2592 Post by d00zah » Tue Dec 17, 2024 1:42 pm
Gedred wrote: Tue Dec 17, 2024 9:51 am Here is the info related to the blu ray drive.
OS device name: F:
Revision: 1.03
Hardware is too old for UHD. DON"T try to flash.
Gedred
#2593 Post by Gedred » Tue Dec 17, 2024 1:58 pm
Thanks for your help, I suspected as much!
Can get same drive on Amazon new at around £70, presume that will be able to implement flash for UHD?
#2594 Post by Coopervid » Tue Dec 17, 2024 3:36 pm
Post your Makemkv info for your Verbatim drive.
Gedred
#2595 Post by Gedred » Tue Dec 17, 2024 6:45 pm
I have sent it back, as it was supposed to work straight out of the box, it didn't! I spent too long messing with settings in VLC Media but could not get it to read from the drive.
