thanks, e.g. on Chroma Weight extreme values 0-4095 DV P8 cmv4.0.mp4 I see a lot of chnages, espcially in "Chroma weight 0" - it bascially created dark whole in the beak.RESET_9999 wrote: Tue Dec 17, 2024 11:52 amas long as you see that the RPU levels are used (brightness changes), you're fine.darrrkmanxxx wrote: Tue Dec 17, 2024 9:28 am Hey guys, is there a way to be able to tell if DV works properly on my device or not. I've downloaded a bunch of test files and they all trigger dolby vision but I'm not sure how to interpret them, especially the player/tv-led stuff (chroma weight)
Any guidance/help will be appreciated.
This is desirable, right?
It's on my Philips TV Oled+ internal player.
