Chisum04
#10471 Post by Chisum04 » Tue Dec 17, 2024 10:53 am
Regarding the saturation in "Strange Darling" (UK) there is a review on bluray.com citing an interview with Cinematographer Giovanni Ribisi, who "sought an explosive color saturation". I think he found it.
#10472 Post by RESET_9999 » Tue Dec 17, 2024 11:52 am
darrrkmanxxx wrote: Tue Dec 17, 2024 9:28 am Hey guys, is there a way to be able to tell if DV works properly on my device or not. I've downloaded a bunch of test files and they all trigger dolby vision but I'm not sure how to interpret them, especially the player/tv-led stuff (chroma weight)
Any guidance/help will be appreciated.
as long as you see that the RPU levels are used (brightness changes), you're fine.
#10473 Post by RESET_9999 » Tue Dec 17, 2024 12:01 pm
Chisum04 wrote: Tue Dec 17, 2024 10:53 am Regarding the saturation in "Strange Darling" (UK) there is a review on bluray.com citing an interview with Cinematographer Giovanni Ribisi, who "sought an explosive color saturation". I think he found it.
Still 10 times more saturated than the SDR grade which doesn't make much sense.
https://slow.pics/c/SA2frBoy
darrrkmanxxx
#10474 Post by darrrkmanxxx » Tue Dec 17, 2024 1:11 pm
RESET_9999 wrote: Tue Dec 17, 2024 11:52 am
thanks, e.g. on Chroma Weight extreme values 0-4095 DV P8 cmv4.0.mp4 I see a lot of chnages, espcially in "Chroma weight 0" - it bascially created dark whole in the beak.
This is desirable, right?
It's on my Philips TV Oled+ internal player.
#10475 Post by RESET_9999 » Tue Dec 17, 2024 1:12 pm
yes
you should try the cmv2.9 version as well, on both of my 2022 TVs (LG , hisense) , it doesn't work.
darrrkmanxxx
#10476 Post by darrrkmanxxx » Tue Dec 17, 2024 1:21 pm
RESET_9999 wrote: Tue Dec 17, 2024 1:12 pm yes
Thank you so much, I'll try that.
Another quick question:
In one of your yt videos (6 different things FEL Dolby Vision Profile 7 Can Do (P7 FEL is not just 12bits)) you mention baked FEL.
How is this done, through MakeMKV?
#10477 Post by RESET_9999 » Tue Dec 17, 2024 1:27 pm
You need an hdmi device that supports FEL decoding like one of these: https://discourse.coreelec.org/t/ce-ng- ... 05x4/50953
Otherwise, re-encoding is required to bake FEL in the BL. (workflow 8-2-1 in dovi_scripts)
darrrkmanxxx
#10478 Post by darrrkmanxxx » Tue Dec 17, 2024 1:37 pm
RESET_9999 wrote: Tue Dec 17, 2024 1:27 pm You need an hdmi device that supports FEL decoding like one of these: https://discourse.coreelec.org/t/ce-ng- ... 05x4/50953
got you, I might get my hands on a Dune HD Premier 4K Pro this weekend. According to your docs Dune hase fake-tv led DV.
Is it the case only wehn using andoid or coreelec, too?
How should I verify working tv-led, chroma trims?
#10479 Post by RESET_9999 » Tue Dec 17, 2024 1:39 pm
You need the CoreELEC builds for TV-LED and FEL support.
kazuma
#10480 Post by kazuma » Tue Dec 17, 2024 5:03 pm
what does mean tv-led exactly? what is the benefit?
#10481 Post by RESET_9999 » Tue Dec 17, 2024 5:13 pm
it means it's the TV that does the tone mapping and metadata processing. It's more accurate.
LV8HD
#10482 Post by LV8HD » Sat Dec 21, 2024 6:17 pm
@RESET_9999 should I generate a new RPU?
#10483 Post by RESET_9999 » Sat Dec 21, 2024 10:37 pm
No. Some colorists prefer static L1 with dynamic trims.
LV8HD
#10484 Post by LV8HD » Sun Dec 22, 2024 12:24 pm
RESET_9999 wrote: Sat Dec 21, 2024 10:37 pm No. Some colorists prefer static L1 with dynamic trims.
I see, thanks
deadchip12
#10485 Post by deadchip12 » Tue Dec 24, 2024 3:06 pm
I'm trying to generate the hdr10 brightness plot using workflow 6-2 and see these lines. What do they mean?
