Regarding the saturation in "Strange Darling" (UK) there is a review on bluray.com citing an interview with Cinematographer Giovanni Ribisi, who "sought an explosive color saturation". I think he found it.
as long as you see that the RPU levels are used (brightness changes), you're fine.darrrkmanxxx wrote: ↑Tue Dec 17, 2024 9:28 amHey guys, is there a way to be able to tell if DV works properly on my device or not. I've downloaded a bunch of test files and they all trigger dolby vision but I'm not sure how to interpret them, especially the player/tv-led stuff (chroma weight)
Any guidance/help will be appreciated.
Still 10 times more saturated than the SDR grade which doesn't make much sense.
https://slow.pics/c/SA2frBoy
darrrkmanxxx
thanks, e.g. on Chroma Weight extreme values 0-4095 DV P8 cmv4.0.mp4 I see a lot of chnages, espcially in "Chroma weight 0" - it bascially created dark whole in the beak.RESET_9999 wrote: ↑Tue Dec 17, 2024 11:52 amas long as you see that the RPU levels are used (brightness changes), you're fine.darrrkmanxxx wrote: ↑Tue Dec 17, 2024 9:28 amHey guys, is there a way to be able to tell if DV works properly on my device or not. I've downloaded a bunch of test files and they all trigger dolby vision but I'm not sure how to interpret them, especially the player/tv-led stuff (chroma weight)
This is desirable, right?
It's on my Philips TV Oled+ internal player.
yes
you should try the cmv2.9 version as well, on both of my 2022 TVs (LG , hisense) , it doesn't work.
darrrkmanxxx
Thank you so much, I'll try that.RESET_9999 wrote: ↑Tue Dec 17, 2024 1:12 pmyes
Another quick question:
In one of your yt videos (6 different things FEL Dolby Vision Profile 7 Can Do (P7 FEL is not just 12bits)) you mention baked FEL.
How is this done, through MakeMKV?
You need an hdmi device that supports FEL decoding like one of these: https://discourse.coreelec.org/t/ce-ng- ... 05x4/50953
Otherwise, re-encoding is required to bake FEL in the BL. (workflow 8-2-1 in dovi_scripts)
darrrkmanxxx
got you, I might get my hands on a Dune HD Premier 4K Pro this weekend. According to your docs Dune hase fake-tv led DV.RESET_9999 wrote: ↑Tue Dec 17, 2024 1:27 pmYou need an hdmi device that supports FEL decoding like one of these: https://discourse.coreelec.org/t/ce-ng- ... 05x4/50953
Is it the case only wehn using andoid or coreelec, too?
How should I verify working tv-led, chroma trims?
You need the CoreELEC builds for TV-LED and FEL support.
what does mean tv-led exactly? what is the benefit?
it means it's the TV that does the tone mapping and metadata processing. It's more accurate.
No. Some colorists prefer static L1 with dynamic trims.
I see, thanksRESET_9999 wrote: ↑Sat Dec 21, 2024 10:37 pmNo. Some colorists prefer static L1 with dynamic trims.
deadchip12
I'm trying to generate the hdr10 brightness plot using workflow 6-2 and see these lines. What do they mean?
