VERBATIM Blu-Ray Slimline Ultra HD 4K USB (43888 - PIONEER BDR-UD04) burning problem
AlmostAGeek
#1 Post by AlmostAGeek » Sat Dec 14, 2024 7:42 pm
I have a problem with VERBATIM Blu-Ray Slimline Ultra HD 4K USB 3.2 Gen 1 (USB-C) (43888 - PIONEER BDR-UD04 FW: BDR-US04 v1.14 inside).
MakeMKV rips everything without problems, no read problems. But I tried to burn Verbatim 25GB M-Disc in Nero 2020 and i've noticed six pauses during burning. Used read buffer was still at 100% and buffer level was still at 97%. After burn read test was without any slowdown or pauses. I have also LG BH16NS55 (FW: WH16NS60 1.02MK flashed a few days ago - thx guys :). And this LG burns without pauses. Yes, I am a gadgeteer, if that's a word to describe me? Is the Verbatim really better quality than my LG as I´ve read on this forum?
Now another problem, every app can see both my drives, but Nero Discspeed (7.0.2.100) only newer one - Verbatim.
Sorry for such a mess in my post. Pls, any explanation, advice?
P.S.: I'm starting a 4K ripping for my personal use. My very first 4K rip that I am working on is LOTR of course... :) Yep, another fantasy man.
Re: VERBATIM Blu-Ray Slimline Ultra HD 4K USB (43888 - PIONEER BDR-UD04) burning problem
#2 Post by Coopervid » Tue Dec 17, 2024 11:29 am
Most likely a power problem. The Verbatim enclosures are very power hungry. Connect to USB3 or use a powered USB hub.
The Pioneer is the better burner but for 25GB discs it almost doesn't matter. It matters big time if you burn 50GB discs.
AlmostAGeek
#3 Post by AlmostAGeek » Fri Dec 20, 2024 5:26 pm
Thank you for reply.
I'm running the Verbatim drive in USB 3.1 gen 1, which is perhaps the same as USB 3.2 gen 1. Today I tried powered USB hub with the same behaviour as before. Even no matter if I burn M-disc or non-M-disc Verbatim BD-R. There are still several pauses.
I give up, I won't find out where the rub is. I don't even know if this is a reason to complain.
I'll try Verbatim support, wonder what they'll say.
