Pioneer BDR-212DBK vs BDR-212V
seatle89
Re: Pioneer BDR-212DBK vs BDR-212V
Post by seatle89 »
Hey guys,
I just bought a BDR-212V, and would like to enable UHD. Here is the info I see on MakeMKV:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: (redacted)
Firmware date: 2022-05-31
Bus encryption flags: 13
Firmware version: ID06
I saw some posts with similar drives (firmware version, etc.). Could you please PM instructions on how to flash the drive? Thank you!
Payti
Post by Payti »
Coopervid wrote: Mon Dec 16, 2024 10:29 pm And yes we checked that wit LG WH16NS58 1.V5 and VPTools. All newer multilayer discs after Verbatim moved the equipment to Taiwan have issues at the layer break. 50 Gb Ritek are still Ok. Were. These tests are 2 years old. Advice: Stop burning discs!
I wanted backup My family videos from CAM (15 years recording) to BD.
Hm i must consider recording to BD's ...
Payti wrote: Mon Dec 16, 2024 11:02 pm
No. Store on HDD.
lunarglyph
Post by lunarglyph »
Coopervid wrote: Sun Dec 15, 2024 12:03 pm
lunarglyph wrote: Sun Dec 15, 2024 1:35 am @Coopervid, I just bought a DBR-212V. Would you be able to PM me instructions for reflashing? Much appreciated!
PM sent.
Amazing, thank you so much!
seatle89 wrote: Mon Dec 16, 2024 10:52 pm Hey guys,
Revision: 1.02
PM sent.
seatle89
Post by seatle89 »
Coopervid wrote: Tue Dec 17, 2024 11:15 am
Revision: 1.02
PM sent.
Thanks @Coopervid! Worked like a charm!
donniedisko
Post by donniedisko »
Hello, I'm also looking for the firmware to enable UHD disks on my new BDR-212V.
OS device name: G:
Revision: 1.02
Serial number: xxxxxxxxxxxx
Highest AACS version: 68
zaqqaz6917
Post by zaqqaz6917 »
I see in a post above, that Vinpower Australia is now selling drives with newer fw.
Not sure if USA Amazon seller RUNTECHMEDIA supply of compatible Vinpower/Pioneer 212 will last much longer as well.
donniedisko wrote: Wed Dec 18, 2024 12:56 am Hello, I'm also looking for the firmware to enable UHD disks on my new BDR-212V.
OS device name: G:
Revision: 1.02
PM sent.
donniedisko
Coopervid wrote: Wed Dec 18, 2024 10:11 am
OS device name: G:
Revision: 1.02
PM sent.
Success! Thank you. PM me if I can send you a tip via ko-fi or similar for your time.
SLEEPWELL83
Post by SLEEPWELL83 »
Hey I have the BDR-212D and was hoping to enable UHD. Here's the drive info:
OS device name: \Device\CdRom2
Product: BD-RW BDR-212D
Revision: 1.00
Firmware date: 2019-01-10
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: 1.00/ID61
SLEEPWELL83 wrote: Sun Dec 22, 2024 9:42 am Hey I have the BDR-212D and was hoping to enable UHD. Here's the drive info:
Revision: 1.00
PM sent.
D0do42
Post by D0do42 »
I recently acquired a Pioneer BDR-212V, too.
Here's the drive information as shown in MakeMKV:
Revision: 1.02
I would like to enable UHD like the others before me in this thread.
Could you send the instructions to me as well, Coopervid?
D0do42 wrote: Mon Dec 23, 2024 10:06 pm Hello,
Revision: 1.02
PM sent.
D0do42
Post by D0do42 »
Many thanks for the quick response, Coopervid! That worked like a charm. Any way to send you a tip?
Merry Christmas everyone!
