Pioneer BDR-212DBK vs BDR-212V
seatle89
Re: Pioneer BDR-212DBK vs BDR-212V
Hey guys,
I just bought a BDR-212V, and would like to enable UHD. Here is the info I see on MakeMKV:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: (redacted)
Firmware date: 2022-05-31
Bus encryption flags: 13
Firmware version: ID06
I saw some posts with similar drives (firmware version, etc.). Could you please PM instructions on how to flash the drive? Thank you!
Revision: 1.02
Payti
I wanted backup My family videos from CAM (15 years recording) to BD.Coopervid wrote: Mon Dec 16, 2024 10:29 pm And yes we checked that wit LG WH16NS58 1.V5 and VPTools. All newer multilayer discs after Verbatim moved the equipment to Taiwan have issues at the layer break. 50 Gb Ritek are still Ok. Were. These tests are 2 years old. Advice: Stop burning discs!
Hm i must consider recording to BD's ...
No. Store on HDD.Payti wrote: Mon Dec 16, 2024 11:02 pmI wanted backup My family videos from CAM (15 years recording) to BD.Coopervid wrote: Mon Dec 16, 2024 10:29 pm And yes we checked that wit LG WH16NS58 1.V5 and VPTools. All newer multilayer discs after Verbatim moved the equipment to Taiwan have issues at the layer break. 50 Gb Ritek are still Ok. Were. These tests are 2 years old. Advice: Stop burning discs!
lunarglyph
Amazing, thank you so much!Coopervid wrote: Sun Dec 15, 2024 12:03 pmPM sent.lunarglyph wrote: Sun Dec 15, 2024 1:35 am @Coopervid, I just bought a DBR-212V. Would you be able to PM me instructions for reflashing? Much appreciated!
PM sent.seatle89 wrote: Mon Dec 16, 2024 10:52 pm Hey guys,
Revision: 1.02
seatle89
Thanks @Coopervid! Worked like a charm!Coopervid wrote: Tue Dec 17, 2024 11:15 amPM sent.seatle89 wrote: Mon Dec 16, 2024 10:52 pm Hey guys,
Revision: 1.02
donniedisko
Hello, I'm also looking for the firmware to enable UHD disks on my new BDR-212V.
OS device name: G:
Revision: 1.02
Serial number: xxxxxxxxxxxx
Highest AACS version: 68
OS device name: G:
Revision: 1.02
zaqqaz6917
I see in a post above, that Vinpower Australia is now selling drives with newer fw.
Not sure if USA Amazon seller RUNTECHMEDIA supply of compatible Vinpower/Pioneer 212 will last much longer as well.
PM sent.donniedisko wrote: Wed Dec 18, 2024 12:56 am Hello, I'm also looking for the firmware to enable UHD disks on my new BDR-212V.
OS device name: G:
Revision: 1.02
donniedisko
Success! Thank you. PM me if I can send you a tip via ko-fi or similar for your time.Coopervid wrote: Wed Dec 18, 2024 10:11 amPM sent.donniedisko wrote: Wed Dec 18, 2024 12:56 am Hello, I'm also looking for the firmware to enable UHD disks on my new BDR-212V.
OS device name: G:
Revision: 1.02
SLEEPWELL83
Hey I have the BDR-212D and was hoping to enable UHD. Here's the drive info:
OS device name: \Device\CdRom2
Product: BD-RW BDR-212D
Revision: 1.00
Firmware date: 2019-01-10
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: 1.00/ID61
Revision: 1.00
PM sent.SLEEPWELL83 wrote: Sun Dec 22, 2024 9:42 am Hey I have the BDR-212D and was hoping to enable UHD. Here's the drive info:
Revision: 1.00
D0do42
I recently acquired a Pioneer BDR-212V, too.
Here's the drive information as shown in MakeMKV:
I would like to enable UHD like the others before me in this thread.
Could you send the instructions to me as well, Coopervid?
Revision: 1.02
Firmware version: ID06Could you send the instructions to me as well, Coopervid?
PM sent.D0do42 wrote: Mon Dec 23, 2024 10:06 pm Hello,
Here's the drive information as shown in MakeMKV:I would like to enable UHD like the others before me in this thread.Code: Select all
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: (redacted) Firmware date: 2022-05-31 Bus encryption flags: 13 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
D0do42
Many thanks for the quick response, Coopervid! That worked like a charm. Any way to send you a tip?
Merry Christmas everyone!
