Can you do anything for my drive Cooper? please and thanks
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Serial number: [redacted]
Firmware date: 2013-09-10
Highest AACS version: 68
Drive platform: RS8600
Firmware version: E401/ID44
ASUS BD-12D1S-U external drive with pioneer bdr-209
kobra_commader
Re: ASUS BD-12D1S-U external drive with pioneer bdr-209
Sure. You have a PM.kobra_commader wrote: Tue Nov 12, 2024 2:42 am Can you do anything for my drive Cooper? please and thanks
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
kobra_commader
got it flashed but it still doesn't register 4k discs and the BDR software is saying its a BDR-S11 not the 211 in your PM or S12u in the tutorialCoopervid wrote: Wed Nov 13, 2024 10:54 amSure. You have a PM.kobra_commader wrote: Tue Nov 12, 2024 2:42 am Can you do anything for my drive Cooper? please and thanks
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
(it wont let me PM back yet)
S11 is correct. Shut down your PC. Wait a few seconds. Reboot. You didn't follow the instructions I guess.kobra_commader wrote: Fri Nov 15, 2024 3:32 amgot it flashed but it still doesn't register 4k discs and the BDR software is saying its a BDR-S11 not the 211 in your PM or S12u in the tutorialCoopervid wrote: Wed Nov 13, 2024 10:54 amSure. You have a PM.kobra_commader wrote: Tue Nov 12, 2024 2:42 am Can you do anything for my drive Cooper? please and thanks
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
kobra_commader
Its working now that I tried it today, I did shut the computer off along with removing power and usb from it for about 30 seconds right after I flashed it yesterday and it wouldn't read it at all. I guess that wasn't long enoughCoopervid wrote: Fri Nov 15, 2024 4:07 pmS11 is correct. Shut down your PC. Wait a few seconds. Reboot. You didn't follow the instructions I guess.kobra_commader wrote: Fri Nov 15, 2024 3:32 amgot it flashed but it still doesn't register 4k discs and the BDR software is saying its a BDR-S11 not the 211 in your PM or S12u in the tutorial
Thanks for your help Cooper
fastscirocco
I also have a ASUS BD-12D1S-U external drive, MakeMKV shows the following info:
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E301
Firmware date: 2013-02-25
Bus encryption flags: 13
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: E301/ID71
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E301
PM sent.fastscirocco wrote: Mon Dec 16, 2024 10:51 pm I also have a ASUS BD-12D1S-U external drive, MakeMKV shows the following info:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E301
fastscirocco
Thanks, update successfully completed.
globalwarmer
Here's another BD-12D1S-U...can it be flashed for UDH?
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Serial number: xxxxxxxxx
Highest AACS version: 47
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
PM sent.globalwarmer wrote: Sat Jan 04, 2025 8:50 pm Here's another BD-12D1S-U...can it be flashed for UDH?
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
ladiesman217
I'm in the same boat as the others in this thread, and want the UHD support. can i kindly get the guide as well, here is my information from MakeMKV.
Drevinformation
OS drevnavn: F:
Producent: ASUS
Produkt: BW-12D1S-U
Revision: E401
Serienummer: ...
Firmwaredato: 2013-09-10
Krypteringsflag for databus: 1B
LibreDrive-information
Status: Aktiveret
Drev-platform: RS8600
Firmwaretype: Oprindelig (ikke-patchet)
Firmwareversion: E401/ID44
DVD alle regioner: Ja
BD-læsning af rå data: Ja
BD-læsning af rå metadata: Ja
Ubegrænset læsehastighed: Ja
Ingen disk isat
Drevinformation
OS drevnavn: F:
Producent: ASUS
Produkt: BW-12D1S-U
Revision: E401
Serienummer: ...
Status: Aktiveret
Ingen disk isat
PM sent.ladiesman217 wrote: Sat Jan 25, 2025 9:37 am I'm in the same boat as the others in this thread, and want the UHD support. can i kindly get the guide as well, here is my information from MakeMKV.
Drevinformation
OS drevnavn: F:
Producent: ASUS
Produkt: BW-12D1S-U
Revision: E401
Serienummer: ...
Status: Aktiveret
Ingen disk isat
ladiesman217
If any of you who have recieved the guide sees this post could you reach out and send it to me, or even better, post i here in the forum so everyone could get use of it?
I did recieve a PM but unless i make a donation i wont get the guide is the answer.
So? And these files are not supposed to be public. Anyone beware to make them! There are really good reasons that they aren't.ladiesman217 wrote: Sun Jan 26, 2025 5:42 am If any of you who have recieved the guide sees this post could you reach out and send it to me, or even better, post i here in the forum so everyone could get use of it?
I did recieve a PM but unless i make a donation i wont get the guide is the answer.![]()
And you: If you are too cheap to spend a couple of bucks to show your interest and appreciation- forget it.
Coop, you can always stop sending it to people!!! Blackened asked us not to share it with anyone else anyway.Coopervid wrote: Sun Jan 26, 2025 10:05 pmSo? And these files are not supposed to be public. Anyone beware to make them! There are really good reasons that they aren't.ladiesman217 wrote: Sun Jan 26, 2025 5:42 am If any of you who have recieved the guide sees this post could you reach out and send it to me, or even better, post i here in the forum so everyone could get use of it?
