Pioneer BDR-212DBK vs BDR-212V
Re: Pioneer BDR-212DBK vs BDR-212V
@Coopervid,
I bought a BDR-212V FW 1.00. Can you please PM instructions for reflashing for UHD/LibreDrive?
Thanks and regards.
Tom
Thanks and regards.
Tom
Why are you coming here? You got help with your other drive in the Polish forum.Payti wrote: Sun Dec 15, 2024 8:00 pm @Coopervid,
Thanks and regards.
Tom
If You are @jadburner on Polish forum thanks for help. Could be BDR-212V FW1.00 crossflashed to BDR-S12UHT too?Coopervid wrote: Sun Dec 15, 2024 8:48 pm Why are you coming here? You got help with your other drive in the Polish forum.
Regards,
Tom
I'm not. And you also got help from Billy. Are you trying all of us? Don't like that. Try your previous sources.
Maybe he works for Pioneer???
I'm not paranoid but thats weird and I really don't know what he wants to achieve having already two firmware sources. Fishy at least.
zaqqaz6917
@payti
Why do you want to crossflash yet again.??
Are you starting a crossfkash library
Hi I recently acquired a second hand BDR-212DBK and looking to enable UHD can anyone help please.
Post your Makemkv info.Otaku wrote: Mon Dec 16, 2024 10:15 am Hi I recently acquired a second hand BDR-212DBK and looking to enable UHD can anyone help please.
IShopper42
Hi Billycar11,
I ordered a BDR-212V from Vinpower Digital's Australian office. The drive I was shipped is labeled as a DBR-212BK. I was told to test the drive to see if it is UHD enabled. This is what I get from MakeMKV:
Regards,
Ian.
Is this drive unlockable?Drive Information
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-212BK
Revision: 1.04
Serial number: (Redacted)
Firmware date: 2022-12-20
Firmware version: ID81
Regards,
Ian.
No return it I still have the newest gen pioneers with old fw if you want one see belowIShopper42 wrote: Mon Dec 16, 2024 3:40 pm Hi Billycar11,
I ordered a BDR-212V from Vinpower Digital's Australian office. The drive I was shipped is labeled as a DBR-212BK. I was told to test the drive to see if it is UHD enabled. This is what I get from MakeMKV:Is this drive unlockable?Drive Information
OS device name: G:
Revision: 1.04
Regards,
Ian.
IShopper42
Hi Billycar11,
I just sent you an email requesting further information.
Regards,
Ian.
Regards,
Ian.
Heh, not working for Pionieerzaqqaz6917 wrote: Mon Dec 16, 2024 6:14 am@payti
Are you starting a crossfkash library![]()
but I want crosflash them now for BDR-S12J-X (UHD/LibreDrive firmware) and test quality for writing BD with this firmware. Could be possible send me files?
Ask your former sources. BTW- write quality never improved from 211 to 212 and 213. Much jaddajadda by Pioneer. And don't burn anymore. This is so much before yesterday. Expensive, bad disk quality and degrading. We store now on hard disks and use players.Payti wrote: Mon Dec 16, 2024 9:48 pmHeh, not working for Pionieerzaqqaz6917 wrote: Mon Dec 16, 2024 6:14 am@paytiPayti wrote: Sun Dec 15, 2024 9:33 pm
Regards,
Tom
and I have second drive BDR-212V FW1.00 (tested, crossflashed to BDR-S12UHT successfull)
And yes we checked that wit LG WH16NS58 1.V5 and VPTools. All newer multilayer discs after Verbatim moved the equipment to Taiwan have issues at the layer break. 50 Gb Ritek are still Ok. Were. These tests are 2 years old. Advice: Stop burning discs!
