Closed Caption Support
apuorro
#1 Post by apuorro » Thu Dec 24, 2009 1:52 am
Is there a way to support the extraction of, or preservation of, closed captions on makeMKV? I have found that the mkv files created by MakeMKV strip out the closed captions. If I create the files with mkvmerge, the closed captions are still extractable.
It would be great if there were an option to create an srt file or subtitle track for the closed caption when MakeMKV creates the title files.
Any chance of this?
Thanks in advance...
Re: Closed Caption Support
#2 Post by mike admin » Thu Dec 24, 2009 11:39 am
this is a known limitation. it is on the todo list but timeline for it is unknown.
Sidrack
#3 Post by Sidrack » Sat Oct 22, 2011 9:33 pm
So it's impossible to extract these things to a MATROSKA file? Will I have to keep the original discs?
Are there other alternatives to do this, besides MAKEMKV?
setarip_old
#4 Post by setarip_old » Sun Oct 23, 2011 12:17 am
@Sidrack
1) This thread was last posted to 22 months ago - and with a specific response by "mike admin"
2) This is a forum for beta testing MakeMKV. If you are seeking alternatives, do a Googlesearch
3) Multiple posting of the same, slightly modified question is not appreciated
SystemDisc
#5 Post by SystemDisc » Mon Jan 09, 2017 3:23 am
Sidrack wrote:So it's impossible to extract these things to a MATROSKA file? Will I have to keep the original discs?
You can use CCExtractorGUI to extract the CC Subtitles from the VOB files and MKVToolNix to mux the SRT file into the MKV. See: https://www.makemkv.com/forum2/viewtopic.php?f=7&t=4205
