Pioneer BDR-212DBK vs BDR-212V
Payti
Re: Pioneer BDR-212DBK vs BDR-212V
#151 Post by Payti » Sun Dec 15, 2024 8:00 pm
@Coopervid,
I bought a BDR-212V FW 1.00. Can you please PM instructions for reflashing for UHD/LibreDrive?
Thanks and regards.
Tom
#152 Post by Coopervid » Sun Dec 15, 2024 8:48 pm
Payti wrote: Sun Dec 15, 2024 8:00 pm @Coopervid,
Thanks and regards.
Tom
Why are you coming here? You got help with your other drive in the Polish forum.
Payti
#153 Post by Payti » Sun Dec 15, 2024 9:33 pm
Coopervid wrote: Sun Dec 15, 2024 8:48 pm Why are you coming here? You got help with your other drive in the Polish forum.
If You are @jadburner on Polish forum thanks for help. Could be BDR-212V FW1.00 crossflashed to BDR-S12UHT too?
Regards,
Tom
#154 Post by Coopervid » Sun Dec 15, 2024 9:35 pm
I'm not. And you also got help from Billy. Are you trying all of us? Don't like that. Try your previous sources.
#155 Post by MartyMcNuts » Sun Dec 15, 2024 11:28 pm
Thanks and regards.
Tom
Maybe he works for Pioneer???
#156 Post by Coopervid » Sun Dec 15, 2024 11:45 pm
MartyMcNuts wrote: Sun Dec 15, 2024 11:28 pm
Thanks and regards.
Tom
I'm not paranoid but thats weird and I really don't know what he wants to achieve having already two firmware sources. Fishy at least.
zaqqaz6917
#157 Post by zaqqaz6917 » Mon Dec 16, 2024 6:14 am
Payti wrote: Sun Dec 15, 2024 9:33 pm
Regards,
Tom
@payti
Why do you want to crossflash yet again.??
Are you starting a crossfkash library :mrgreen:
Otaku
#158 Post by Otaku » Mon Dec 16, 2024 10:15 am
Hi I recently acquired a second hand BDR-212DBK and looking to enable UHD can anyone help please.
#159 Post by Coopervid » Mon Dec 16, 2024 11:55 am
Otaku wrote: Mon Dec 16, 2024 10:15 am Hi I recently acquired a second hand BDR-212DBK and looking to enable UHD can anyone help please.
Post your Makemkv info.
IShopper42
#160 Post by IShopper42 » Mon Dec 16, 2024 3:40 pm
Hi Billycar11,
I ordered a BDR-212V from Vinpower Digital's Australian office. The drive I was shipped is labeled as a DBR-212BK. I was told to test the drive to see if it is UHD enabled. This is what I get from MakeMKV:
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-212BK
Revision: 1.04
Serial number: (Redacted)
Firmware date: 2022-12-20
Firmware version: ID81
Is this drive unlockable?
Regards,
Ian.
#161 Post by Billycar11 » Mon Dec 16, 2024 3:47 pm
IShopper42 wrote: Mon Dec 16, 2024 3:40 pm Hi Billycar11,
OS device name: G:
Revision: 1.04
Regards,
Ian.
No return it I still have the newest gen pioneers with old fw if you want one see below
IShopper42
#162 Post by IShopper42 » Mon Dec 16, 2024 4:01 pm
Hi Billycar11,
I just sent you an email requesting further information.
Regards,
Ian.
Payti
#163 Post by Payti » Mon Dec 16, 2024 9:48 pm
zaqqaz6917 wrote: Mon Dec 16, 2024 6:14 am
Regards,
Tom
@payti
Heh, not working for Pionieer :D and I have second drive BDR-212V FW1.00 (tested, crossflashed to BDR-S12UHT successfull)
but I want crosflash them now for BDR-S12J-X (UHD/LibreDrive firmware) and test quality for writing BD with this firmware. Could be possible send me files?
#164 Post by Coopervid » Mon Dec 16, 2024 10:21 pm
Payti wrote: Mon Dec 16, 2024 9:48 pm
Regards,
Tom
@payti
Ask your former sources. BTW- write quality never improved from 211 to 212 and 213. Much jaddajadda by Pioneer. And don't burn anymore. This is so much before yesterday. Expensive, bad disk quality and degrading. We store now on hard disks and use players.
#165 Post by Coopervid » Mon Dec 16, 2024 10:29 pm
And yes we checked that wit LG WH16NS58 1.V5 and VPTools. All newer multilayer discs after Verbatim moved the equipment to Taiwan have issues at the layer break. 50 Gb Ritek are still Ok. Were. These tests are 2 years old. Advice: Stop burning discs!
