Fatal error occurred, program will now exit.
datsun80
Post by datsun80 » Mon Dec 16, 2024 1:18 am
I'm getting the following error when saving to MKV: Fatal error occurred, program will now exit. I am using version 1.17.8 and I also tried older versions.
I don't see any messages in the log when this is triggered. The program successfully opens the disk and allows me to select the title I want. It then runs for about 2 min and this error pops up.
I exchanged the disk thinking maybe it was a disk issue but the new one does the same thing. If it matters it is 4k Black Panther.
Here is information on my drive:
OS device name: E:
Product: BD-RE BU40N
Revision: 1.03
Serial number: [redacted]
Highest AACS version: 77
Firmware version: 1.03
Disc Information
Label: BLACK_PANTHER
Timestamp: 2018-03-26 16:33:34
Protection: AACS2.0/C v61
Data capacity: 57.7 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
This is all I see in the debug log:
Debug log started at Mon Dec 16 01:11:30 2024 , written by MakeMKV v1.17.8 win(x64-release)
001005:0000 MakeMKV v1.17.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:/MakeMKV_log.txt
DEBUG: Code 3 at E}P)4^&Zt'eI2]i`NTMR>^^t:29395310
SDF v098: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MOBM2QG1204
Application exited at Mon Dec 16 01:12:41 2024
Re: Fatal error occurred, program will now exit.
Post by dcoke22 » Mon Dec 16, 2024 7:10 am
Does your setup work with other UHDs? DVDs? Regular blu-rays?
Does MakeMKV get the fatal with just this particular disc or all discs?
datsun80
Post by datsun80 » Fri Dec 20, 2024 2:14 am
Yes, it works with all other disc's. Only this disc (both first and replacement copies). It is quite per-plexing.
datsun80
Post by datsun80 » Fri Dec 20, 2024 2:15 am
Forgot to mention that it works with another program so I confirmed the disc and drive are fine. Seems to be something in MakeMKV that is the issue.
datsun80
Post by datsun80 » Fri Dec 27, 2024 5:57 am
I receieved the same error this time for a different movie. Starting to think something is wrong with the install. I did un-install and re-install. I also tried downgrading versions. No luck. Are there issues with Win 11 and MakeMKV?
I went back and tried disc's that previously worked and now they don't. I did try a reg Blu-Ray and it also didn't work.
What is the best way to troubleshoot this?
datsun80
Post by datsun80 » Fri Dec 27, 2024 10:18 pm
I found some logs in the event viewer. Does this mean anything to anyone?
Faulting application name: makemkvcon64.exe, version: 1.17.8.0, time stamp: 0x66f872a2
Faulting module name: makemkvcon64.exe, version: 1.17.8.0, time stamp: 0x66f872a2
Exception code: 0xc0000005
Fault offset: 0x000000000025f794
Faulting process id: 0x1F64
Faulting application start time: 0x1DB58AC8B16EAC4
Faulting application path: C:\Program Files (x86)\MakeMKV\makemkvcon64.exe
Faulting module path: C:\Program Files (x86)\MakeMKV\makemkvcon64.exe
Report Id: 08f4df49-1a82-43a2-8cfd-9684ab79affd
Faulting package full name:
Faulting package-relative application ID:
Fault bucket , type 0
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: makemkvcon64.exe
P2: 1.17.8.0
P3: 66f872a2
P4: makemkvcon64.exe
P5: 1.17.8.0
P6: 66f872a2
P7: c0000005
P8: 000000000025f794
P9:
P10:
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_makemkvcon64.exe_8f54421a522b3a67938a06365ca65161b4b4338_5847651d_c039fb47-e2c9-4d9a-83b6-d634114c18b4
Analysis symbol:
Rechecking for solution: 0
Report Status: 4
Hashed bucket:
Cab Guid: 0
Event Name: BlueScreen
Cab Id: 0
Problem signature:
P1: 3b
P2: c0000005
P3: fffff80542a07f38
P4: fffffe83dcafe910
P5: 0
P6: 10_0_26100
P7: 0_0
P8: 768_1
P9:
P10:
\\?\C:\WINDOWS\Minidump\122624-10046-01.dmp
\\?\C:\WINDOWS\SystemTemp\WER-10062-0.sysdata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.561be5e2-349e-4940-995f-6c3bede80ff2.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.855e5552-6fd7-496e-a241-f6cb33ecf860.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.fe2154f7-a132-4e8f-8581-e10b275ed9fa.tmp.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.52d53400-2b29-46bd-8cb6-3edf2f32274c.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Kernel_3b_84e7ff026f648f49363d2335864d29455263c47_00000000_bacc76ff-9b0e-4692-888a-b18d8a106330
Analysis symbol:
Report Id: 035a2078-b9de-4424-af4b-06fcf1a85f5f
Report Status: 2051
Hashed bucket:
Cab Guid: 0
Fault bucket 1255875824270851569, type 4
Cab Id: 0
Problem signature:
P2: 1.17.8.0
P3: 66f872a2
P5: 1.17.8.0
P6: 66f872a2
P7: c0000005
P9:
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.ff03239c-7d1f-4385-8543-8433cb503bae.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_makemkvcon64.exe_8f54421a522b3a67938a06365ca65161b4b4338_5847651d_c039fb47-e2c9-4d9a-83b6-d634114c18b4
Analysis symbol:
Report Status: 268435456
Hashed bucket: 42f735678ea2d500616dc46883aa3df1
Cab Guid: 0
