Verbatim 43888 with LG drive?
Seoska
#1 Post by Seoska » Fri Dec 06, 2024 7:47 am
Bought a Verbatim 43888 as i was told it will work straight out of the box. Just received the Verbatim 43888 which i bought from Amazon and it seems like they have changed drives as the drive info in makemkv is showing an LG drive?
OS device name: /dev/rdisk3
Product: BD-RE BU40N
Revision: 1.05
Serial number:
Highest AACS version: 60
Should I send this back and try and find an older version? Or can this be used?
Re: Verbatim 43888 with LG drive?
#2 Post by MartyMcNuts » Fri Dec 06, 2024 9:10 am
Seoska wrote: Fri Dec 06, 2024 7:47 am Bought a Verbatim 43888 as i was told it will work straight out of the box. Just received the Verbatim 43888 which i bought from Amazon and it seems like they have changed drives as the drive info in makemkv is showing an LG drive?
Revision: 1.05
Serial number:
Can you show us some pics of this drive? Are you sure you purchased a Verbatim 43888? The info shown is for a LG BU40N, which can be used, it just needs to be flashed first.
Seoska
#3 Post by Seoska » Fri Dec 06, 2024 9:50 am
Im surprised about that too but its definitely a verbatim. Sold and shipped from Amazon AU. Looks like verbatim may have switched suppliers?
Seoska
#4 Post by Seoska » Fri Dec 06, 2024 10:14 am
Packaging
#5 Post by Billycar11 » Fri Dec 06, 2024 12:03 pm
urf well there goes that one
hate when company's do that swap the specs but not update the name they should have renamed it the 43891 since the ud03 was the 43890.
jonghotti
#6 Post by jonghotti » Sat Dec 07, 2024 3:15 pm
So the Verbatim has a BU40 in it. Just like the Buffalo and the Archgon, cool.
ripthem
#7 Post by ripthem » Sun Dec 08, 2024 2:20 pm
I just bought the same from Amazon, the package looks exactly the same!
But makemkv says this:
OS device name: /dev/rdisk4
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Drive platform: RS8A10
Firmware version: 1.14
Checking the label on the drive, it says Model code: KIAB
It also mentions "LibreDrive" when opening a disk!
To be on the sure side, I bought a second drive - will check and write when I got it!
Seoska
#8 Post by Seoska » Sun Dec 08, 2024 10:55 pm
Would have preferred the Pioneer version but have flashed the LG drive to firmware 1.03MK and its ripping with no issues.
Went into a bricks and mortar store to compare the packaging and they are identical. There is no unique identifier on the box to know whether or not the drive is a LG or Pioneer. So from here on in it will just be pot luck on which drive you receive. Unless you know the store has really old stock.
Thanks to ripthem we know based on the label on the physical drive that:
Model Code: KIAA = LG Drive
Model Code: KIAB = Pioneer Drive
I find that model code a little strange as you would think the Pioneer would be A as its an earlier version.
Would be good if someone can post a model code of an older version that at least 12 months old.
ryley
#9 Post by ryley » Mon Dec 09, 2024 2:21 pm
Seoska wrote: Sun Dec 08, 2024 10:55 pm Model Code: KIAA = LG Drive
For what it is worth, I have a Pioneer Verbatim 43888 with the model code KIAA. I purchased the drive about 12 months ago.
#10 Post by MartyMcNuts » Wed Dec 11, 2024 12:35 am
I have both the Pioneer version and the LG version. From what I can tell, the bottom of the box is a little different and the LG drive tray fascia plate has the Super Multi and Blu-Ray logo's on them whereas the Pioneer version drive tray fascia plate is all black.
The Verbatim 43888 containing the LG BU40N has a picture of the drive in the bottom right corner. Looking at the box may help you if you are purchasing from a physical store...
Verbatim 43888 - Pioneer BDR-UD04.jpg (460.43 KiB) Viewed 57127 times
Verbatim 43888 - LG BU40N.jpg (464.99 KiB) Viewed 57127 times
#11 Post by Billycar11 » Sun Dec 15, 2024 9:01 am
makwm wrote: Sun Dec 15, 2024 7:45 am Hi Seoska-
I got the same Verbatim LG Drive from Amazon as yours (and it is not supported by MakeMKV) too. I bought the Verbatim 43888 UHD Drive from Amazon AU (Model Code: KIAA, P/N: 43888), but the order was fulfilled by Amazon Germany.
I am unfamiliar with firmware flashing. May I know how do you flash its firmware?
What software tools you use?
And from where I can download the correct firmware version to be used to flash the drive’s firmware?
Appreciate your help and advice. Thanks in advance!
if its the BU40N see below for guide or if you want an auto flasher me and marty have that too
#12 Post by Coopervid » Sun Dec 15, 2024 12:07 pm
Please post your Makemkv info.
Mr_Orange
#13 Post by Mr_Orange » Sun Dec 15, 2024 10:05 pm
I bought the same thing (Amazon AU fulfilled by Amazon Germany) and I received the Pioneer version. The model code is KIAB.
OS device name: M:
Revision: 1.14
Serial number: ############
Highest AACS version: 77
#14 Post by Coopervid » Sun Dec 15, 2024 10:34 pm
Good for you. But they seem to switch to LG drives, Bad but the BU40N is at least the best LG drive.
Mr_Orange
#15 Post by Mr_Orange » Sun Dec 15, 2024 10:42 pm
Coopervid wrote: Sun Dec 15, 2024 10:34 pm Good for you. But they seem to switch to LG drives, Bad but the BU40N is at least the best LG drive.
The whole reason I bought it was to add a Pioneer to my ripping capability so I would not have been happy if they had sent my an LG version.
Interestingly, the Verbatim is slower than my desktop LG BN16NS55 (flashed to WH16NS60 1.02MK) as it taps out at 4.0x ripping speed.
