Very generous! I wouldn't give them anymore than 48 hours!! If they really want help they should be constantly checking the forum.Coopervid wrote: Sat Dec 14, 2024 8:38 pm FYI: There are a lot of one time posters who ask for help and then never read their PM to get their drive fixed. This is extremely disappointing. People ask for help, get help and then never check their PMs. That's why I will delete all PMs with help for these people when not read within 14 days. And will not PM again. They need to try to get help elsewhere.
BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
DaBaDa79
Hi there,Coopervid wrote: Sat Dec 14, 2024 8:38 pm FYI: There are a lot of one time posters who ask for help and then never read their PM to get their drive fixed. This is extremely disappointing. People ask for help, get help and then never check their PMs. That's why I will delete all PMs with help for these people when not read within 14 days. And will not PM again. They need to try to get help elsewhere.
I'd love to react to your PM but unfortunately I did not receive any until now. Did I miss anything I have to do?
Regards, Daniel
I Misse your post. Read PM.DaBaDa79 wrote: Sat Dec 14, 2024 6:14 pmOf course, here you go:Code: Select all
Laufwerksinformation OS-Gerätename: E: Produzent: PIONEER Produkt: BD-RW BDR-XS07 Revision: 1.01 Serienummer: xxxxx Firmware-Datum: 2020-09-03 Markierungen der Bus-Verschlüsselung: 13 Highest AACS version: 81 I missed your post. Pm is coming. LibreDrive Information Status: Enabled Drive platform: RS8E20 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.01 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
DaBaDa79
Thank you very much - works like a charmCoopervid wrote: Sun Dec 22, 2024 12:44 amI Misse your post. Read PM.DaBaDa79 wrote: Sat Dec 14, 2024 6:14 pmOf course, here you go:Coopervid wrote: Fri Dec 13, 2024 10:25 am
Post your Makemkv info. I will then send a PM accordingly.Code: Select all
CDR Woo
I'm just getting into attempting to rip my 4k discs to Plex. From what I have been reading this drive can be patched for UHD? Or do I need to get an actual UHD drive?
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: ...
Firmware date: 2020-09-03
Bus encryption flags: 13
OS device name: H:
Revision: 1.01
Serial number: ...
See below you can email me for itCDR Woo wrote: Tue Jan 07, 2025 2:53 pm I'm just getting into attempting to rip my 4k discs to Plex. From what I have been reading this drive can be patched for UHD? Or do I need to get an actual UHD drive?
OS device name: H:
Revision: 1.01
Serial number: ...
xplosive777
Hello and thanks in advance, I have this drive and would like help flashing it to become UHD compatible. Here is the info on my BDR-XS07S Slim Slot load.
OS device name: E:
Current profile: BD-R SRM
Revision: 1.00
Serial number: SIDxxxxxxUC
Firmware date: 2019-01-07
Firmware version: 1.00
OS device name: E:
Revision: 1.00
See email below for the flasher just copy paste that info to mexplosive777 wrote: Wed Jan 15, 2025 10:24 pm Hello and thanks in advance, I have this drive and would like help flashing it to become UHD compatible. Here is the info on my BDR-XS07S Slim Slot load.
OS device name: E:
Revision: 1.00
xplosive777
Is there an alternative to purchasing the autoflash kit? If you, Coopervid or anyone else has instructions and the tools to flash myself I would prefer to try that first.
Viola
Hi, I've recently brought an unit of BDR-XS07TS for 70 bucks and it have the firmware number 1.01, can you help me with the tool for flash it with the UHD modded firmware?
hILDA
OS device name: /dev/rdisk5
Revision: 1.01
Serial number: ...
Highest AACS version: 25
Looking for UHD Rip with my old new Pioneer Drive
Revision: 1.01
Serial number: ...
Donations are also welcome here. I have again a lot of one-time-posters who don't read their PMs. You need to show your interest.
Bradley2025
Hi Coopervid
Thanks for all your help on this forum.
Would you be able to help unlock my drive for UHD.
Here is the info
Many thanks
OS device name: /dev/rdisk4
Revision: 1.01
Serial number: ...
Highest AACS version: 23
Here is the info
Many thanks
Revision: 1.01
Serial number: ...
Viola
Hi, I've a problem with the software that doesn't wotk and say me "drive and firmware hardware types don't match", I've tried run as administrator and the force flash setting is enable. I'm on Windows 11 24H2 build 26100.2605
