8 1/2 4K UHD (Criterion) - Dump Submitted
mrm21632
Including here so others can fetch to include in the keydb as needed. I've already submitted this file to svq@makemkv.com as needed for adding to MakeMKV's database.
keydb_helper
Re: 8 1/2 4K UHD (Criterion) - Dump Submitted
Thank you for attaching the disc dump but your particular disc has been fully supported by the public keydb since December 5.mrm21632 wrote: Thu Dec 12, 2024 10:45 pm Including here so others can fetch to include in the keydb as needed. I've already submitted this file to svq@makemkv.com as needed for adding to MakeMKV's database.
Public KeyDB Disc Submissions
mrm21632
Ah gotcha, no worries.keydb_helper wrote: Fri Dec 13, 2024 3:46 am Thank you for attaching the disc dump but your particular disc has been fully supported by the public keydb since December 5.
