ASUS SBW-06D2X-U
Bigfoot18
Re: ASUS SBW-06D2X-U
Post by Bigfoot18 » Fri Dec 13, 2024 8:40 pm
Any info if this is UHD compatible?
OS device name: F:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.03
Serial number: REDACTED
Firmware date: 2016-12-16
Drive platform: RS8510
Firmware version: 1.03/ID22
Post by Coopervid » Sat Dec 14, 2024 10:49 am
OS device name: F:
Manufacturer: ASUS
Revision: 1.03
Not yet. Only after you check your PM and follow the steps.
Bigfoot18
Post by Bigfoot18 » Sat Dec 14, 2024 6:26 pm
OS device name: F:
Manufacturer: ASUS
Revision: 1.03
Sweet that worked! Drive is now reading as Pioneer BDR-UD04.
Gen86
Post by Gen86 » Thu Dec 19, 2024 11:54 am
Hi, would I be able to get the instructions as well?
Here's my drive information:
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
Serial number: [redacted]
Firmware date: 2017-04-18
Firmware version: ID22
Post by Coopervid » Thu Dec 19, 2024 3:00 pm
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
PM sent.
_Lilac_
Post by _Lilac_ » Mon Dec 23, 2024 10:58 am
Hi there, I recently purchased this drive and am wondering if I would be able to get these instructions also?
Here is my drive information:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Highest AACS version: 68
Thank you very much in advance
Post by Coopervid » Mon Dec 23, 2024 4:10 pm
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM sent.
DMan13
Post by DMan13 » Mon Dec 23, 2024 7:38 pm
Hello there,
I have the same drive. Was wondering if I could get the instructions on how to UHD compatible?
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Post by Coopervid » Tue Dec 24, 2024 5:15 pm
Hello there,
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM is coming.
DMan13
Post by DMan13 » Tue Dec 24, 2024 8:09 pm
Everything worked 100% and went smooth. Thanks really appreciate it!
Part-Time_Ripper
Post by Part-Time_Ripper » Fri Dec 27, 2024 3:04 am
Hi there, I am looking to flash my firmware for UHD. Thanks in advance.
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Highest AACS version: 77
Post by Coopervid » Fri Dec 27, 2024 11:35 am
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM is coming.
dagobert-0815
Post by dagobert-0815 » Sun Dec 29, 2024 3:44 pm
Hello everyone,
I also have an SBW-06D2X-U from Asus. Can someone please help me to make the device UHDfriendly? I am fit on the command line, but I have no idea how to flash a Blu-Ray drive without bricking it.
I'm using a Linux OS and here is the drive information:
OS device name: /dev/sr0
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Bus encryption markings: 1B
Highest AACS version: 75
Many thanks in advance and best regards
Post by Coopervid » Mon Dec 30, 2024 7:29 pm
Hello everyone,
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
You need to have access to a Windows PC.
dagobert-0815
Post by dagobert-0815 » Mon Dec 30, 2024 9:56 pm
Hello everyone,
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
That's not a problem. I have a dual boot system.
