Dump Submitted - Alienoid 2 UHD
FhiiZo
MKB20_v77_Alienoid2_21DA
keydb_helper
Re: Dump Submitted - Alienoid 2 UHD
The 21DA variant of Alienoid 2 has been added to the public keydb
Public KeyDB Disc Submissions
FhiiZo
Ok so I can decrypt my disc in 1 or 2 days ?keydb_helper wrote: Fri Dec 13, 2024 2:49 pmThe 21DA variant of Alienoid 2 has been added to the public keydb
keydb_helper
You can decrypt your disc now but you'll need to configure MakeMKV to use the public keydb first. Follow my instructions here
FhiiZo
English or french DB ?keydb_helper wrote: Sat Dec 14, 2024 1:35 amYou can decrypt your disc now but you'll need to configure MakeMKV to use the public keydb first. Follow my instructions here
keydb_helper
Both the English and French DB have the exact same keys. The only difference is how disc titles are listed. So either option would work for you. Just make sure you follow the instructions carefully and unzip the downloaded file.
FhiiZo
For the keydb I can paste the file in the .tgz makemkv folder ?keydb_helper wrote: Sat Dec 14, 2024 9:21 amBoth the English and French DB have the exact same keys. The only difference is how disc titles are listed. So either option would work for you. Just make sure you follow the instructions carefully and unzip the downloaded file.
keydb_helper
Download the keydb_eng.zip fileFhiiZo wrote: Sat Dec 14, 2024 10:47 am For the keydb I can paste the file in the .tgz makemkv folder ?
Unzip the keydb_eng.zip to get keydb.cfg
Copy the keydb.cfg file to the ".tgz makemkv folder"
Do not paste the keydb_eng.zip or keydb_fra.zip files into the ".tgz makemkv folder"
