SilverSurfer
Post
by SilverSurfer » Fri Dec 13, 2024 5:32 pm
dcoke22 wrote: Tue Nov 26, 2024 2:45 pm
The Verbatim 43888 has a Pioneer UD04 inside it that works out of the box. It is generally available in Europe. It isn't the best drive, but it is probably better than the LG you mentioned.
Hey, thanks a lot.
I bought the 43888 and it works perfectly.
Price wise it’s also acceptable.
Sorry for my late response.
Post
by dcoke22 » Fri Dec 13, 2024 8:23 pm
SilverSurfer wrote: Fri Dec 13, 2024 5:32 pm
Hey, thanks a lot.
Excellent.
For future reference, very recently there have been a couple reports that the Verbatim 43888 might come with an LG drive inside it instead of the Pioneer.
Verbatim 43888 with LG drive? The LG drive in there can still be flashed to be LibreDrive compatible.
Post
by Coopervid » Fri Dec 13, 2024 8:28 pm
dcoke22 wrote: Fri Dec 13, 2024 8:23 pm
Hey, thanks a lot.
Excellent.
Until now only in Australia. The BU40 is not bad but the Pioneer is better. Hope the Pioneers will last a bit longer in other regions.
Post
by MartyMcNuts » Fri Dec 13, 2024 8:48 pm
Coopervid wrote: Fri Dec 13, 2024 8:28 pm
Hey, thanks a lot.
Excellent.
We always cop the raw end of things,
ChameleonScales
Post
by ChameleonScales » Fri Jul 18, 2025 11:34 pm
Please pardon my confusion. Am I to understand that a BDR-XS07UHD with firmware v1.03 is unable to play a UHD disc (let alone rip it) and therefore that the text "Playback compatible for Windows 10" is a lie?
The asterisk points to a text that recommends using Cyberlink PowerDVD to play Ultra HD Blu-ray but I tried and it doesn't work. I don't necessarily need to rip my UHD Blu-ray (even though it would be better), I'd just like to know if there's any way whatsoever that I can play it or if I have to return the drive.
Last edited by ChameleonScales on Sun Oct 12, 2025 6:19 pm, edited 1 time in total.
Post
by Billycar11 » Fri Jul 18, 2025 11:44 pm
ChameleonScales wrote: Fri Jul 18, 2025 11:34 pm
play a UHD disc (let alone rip it) and therefore that the text "Playback compatible for Windows *1" is a lie?
it can play it if your pc meets the requirements intel 7th-10th gen sgx enabled and useing the igpu with hdcp 2.2 display
ChameleonScales
Post
by ChameleonScales » Sat Jul 19, 2025 12:12 pm
Thanks. I should've done more research before buying.
So, not that this concerns me anymore (I have an AMD CPU and Nvidia GPU so I'm out of the picture), but I think it should be added that, unless I missed some details, Intel
stopped supporting SGX on their Core processors since at least 2021.
Only Xeon processors still do now.
So this product has at least very narrow requirements on modern hardware at this point, if not worse (haven't looked into it in more detail).
Post
by Billycar11 » Sat Jul 19, 2025 1:26 pm
ChameleonScales wrote: Sat Jul 19, 2025 12:12 pm
I agree it was very dumb to lock playback to one chip OEM but we did get around it if your drive is built before 12/22 for pioneer and still now for LG and rebrands of them
