Dump Submitted - Alienoid 2 UHD
FhiiZo
Post by FhiiZo » Fri Dec 13, 2024 1:17 pm
MKB20_v77_Alienoid2_21DA
keydb_helper
Re: Dump Submitted - Alienoid 2 UHD
Post by keydb_helper » Fri Dec 13, 2024 2:49 pm
FhiiZo wrote: Fri Dec 13, 2024 1:17 pm MKB20_v77_Alienoid2_21DA
The 21DA variant of Alienoid 2 has been added to the public keydb
Public KeyDB Disc Submissions
FhiiZo
Post by FhiiZo » Fri Dec 13, 2024 3:59 pm
keydb_helper wrote: Fri Dec 13, 2024 2:49 pm
Ok so I can decrypt my disc in 1 or 2 days ?
keydb_helper
Post by keydb_helper » Sat Dec 14, 2024 1:35 am
FhiiZo wrote: Fri Dec 13, 2024 3:59 pm Ok so I can decrypt my disc in 1 or 2 days ?
You can decrypt your disc now but you'll need to configure MakeMKV to use the public keydb first. Follow my instructions here
FhiiZo
Post by FhiiZo » Sat Dec 14, 2024 9:16 am
keydb_helper wrote: Sat Dec 14, 2024 1:35 am
English or french DB ?
keydb_helper
Post by keydb_helper » Sat Dec 14, 2024 9:21 am
FhiiZo wrote: Sat Dec 14, 2024 9:16 am English or french DB ?
Both the English and French DB have the exact same keys. The only difference is how disc titles are listed. So either option would work for you. Just make sure you follow the instructions carefully and unzip the downloaded file.
FhiiZo
Post by FhiiZo » Sat Dec 14, 2024 10:47 am
keydb_helper wrote: Sat Dec 14, 2024 9:21 am
For the keydb I can paste the file in the .tgz makemkv folder ?
keydb_helper
Post by keydb_helper » Sat Dec 14, 2024 10:54 am
FhiiZo wrote: Sat Dec 14, 2024 10:47 am For the keydb I can paste the file in the .tgz makemkv folder ?
Download the keydb_eng.zip file
Unzip the keydb_eng.zip to get keydb.cfg
Copy the keydb.cfg file to the ".tgz makemkv folder"
Do not paste the keydb_eng.zip or keydb_fra.zip files into the ".tgz makemkv folder"
