8 1/2 4K UHD (Criterion) - Dump Submitted
mrm21632
Post by mrm21632 » Thu Dec 12, 2024 10:45 pm
Including here so others can fetch to include in the keydb as needed. I've already submitted this file to svq@makemkv.com as needed for adding to MakeMKV's database.
keydb_helper
Re: 8 1/2 4K UHD (Criterion) - Dump Submitted
Post by keydb_helper » Fri Dec 13, 2024 3:46 am
mrm21632 wrote: Thu Dec 12, 2024 10:45 pm Including here so others can fetch to include in the keydb as needed. I've already submitted this file to svq@makemkv.com as needed for adding to MakeMKV's database.
Thank you for attaching the disc dump but your particular disc has been fully supported by the public keydb since December 5.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
mrm21632
Post by mrm21632 » Sat Dec 14, 2024 8:48 pm
keydb_helper wrote: Fri Dec 13, 2024 3:46 am Thank you for attaching the disc dump but your particular disc has been fully supported by the public keydb since December 5.
Ah gotcha, no worries.
