MrMegadeth99
Re: Ultimate UHD Drives Flashing Guide Updated 2024
Sorry I expended the screen to see the full file name
In my downloaded firmware pack the file name is HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin. Not that short as yours. Switch to that directory and do a DIR to see the file name.
SDFToolFlasher. Just start the program and pick the .bin file from that directory that you use in your command line where the .bin is located.
MrMegadeth99
I used the SDFToolflasher and got this error code. Do you know what this means?
Are you in panic mode???MrMegadeth99 wrote: Thu Dec 12, 2024 1:49 pm I used the SDFToolflasher and got this error code. Do you know what this means?
Now you are trying to flash DE_WH16NS40 1.02. You are supposed to flash WH16NS60 1.02. Only after a succesful flash you can also flash other firmware. You understand xxx60 instead of xxx40.
Thee guide recommends...MrMegadeth99 wrote: Thu Dec 12, 2024 1:49 pm I used the SDFToolflasher and got this error code. Do you know what this means?
WH16NS40 on any Firmware directly to > WH16NS60 1.02MK
Download the 'all you need firmware pack' & extract 'HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin'. Flash that.
MrMegadeth99
How do I do that? I only have the options below. I tried the LG WH16NS60 but got the same error code.
You need the MK firmware pack, not the downgrade enabled firmware pack. In the MK firmware pack look under the folder OLD.MrMegadeth99 wrote: Thu Dec 12, 2024 2:03 pm How do I do that? I only have the options below. I tried the LG WH16NS60 but got the same error code.
Or also the all you need firmware pack from Marty listed where SDFToolFlasher is available.
MrMegadeth99
Nevermind I got it thanks for your help
Did it work now?
where did you get those commands?
your copying my directory's thats not going to work
Forget about it Billy. It seems that it finally worked but he didn't even say a thank you after he did things that were missing any logic.Billycar11 wrote: Thu Dec 12, 2024 2:53 pmwhere did you get those commands?
MrMegadeth99
Yes it worked not thanks.
What commands?
What commands?
Bigou
Oh god, I’m an idiot! I forgot to install MakeMKV! THAT was the problem. Once installed, it worked as it should. Thank you for pointing to me what essential part I forgot. (And sorry for the double-post, I was under the impression my message wasn’t sent the first time.)d00zah wrote: Wed Dec 11, 2024 10:51 pmIs MakeMKV installed (in the default location)? SDFtool Flasher is a front-end for the MakeMKV native flash utility. Met all the requirements detailed on the SDFtool Flasher page?
— Bigou
The directory path you used in your power shell script: Billy blahblah. We are sure that directory doesn't exist on your computer.
MrMegadeth99
No clue I just followed the YouTube video
