MrMegadeth99
Re: Ultimate UHD Drives Flashing Guide Updated 2024
Post by MrMegadeth99 » Thu Dec 12, 2024 1:28 pm
Sorry I expended the screen to see the full file name
Post by Coopervid » Thu Dec 12, 2024 1:40 pm
MrMegadeth99 wrote: Thu Dec 12, 2024 1:28 pm Sorry I expended the screen to see the full file name
In my downloaded firmware pack the file name is HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin. Not that short as yours. Switch to that directory and do a DIR to see the file name.
SDFToolFlasher. Just start the program and pick the .bin file from that directory that you use in your command line where the .bin is located.
MrMegadeth99
Post by MrMegadeth99 » Thu Dec 12, 2024 1:49 pm
I used the SDFToolflasher and got this error code. Do you know what this means?
Post by Coopervid » Thu Dec 12, 2024 1:59 pm
MrMegadeth99 wrote: Thu Dec 12, 2024 1:49 pm I used the SDFToolflasher and got this error code. Do you know what this means?
Are you in panic mode???
Now you are trying to flash DE_WH16NS40 1.02. You are supposed to flash WH16NS60 1.02. Only after a succesful flash you can also flash other firmware. You understand xxx60 instead of xxx40.
Post by d00zah » Thu Dec 12, 2024 2:01 pm
Thee guide recommends...
WH16NS40 on any Firmware directly to > WH16NS60 1.02MK
Download the 'all you need firmware pack' & extract 'HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin'. Flash that.
MrMegadeth99
Post by MrMegadeth99 » Thu Dec 12, 2024 2:03 pm
How do I do that? I only have the options below. I tried the LG WH16NS60 but got the same error code.
Post by Coopervid » Thu Dec 12, 2024 2:06 pm
MrMegadeth99 wrote: Thu Dec 12, 2024 2:03 pm How do I do that? I only have the options below. I tried the LG WH16NS60 but got the same error code.
You need the MK firmware pack, not the downgrade enabled firmware pack. In the MK firmware pack look under the folder OLD.
Or also the all you need firmware pack from Marty listed where SDFToolFlasher is available.
MrMegadeth99
Post by MrMegadeth99 » Thu Dec 12, 2024 2:10 pm
Nevermind I got it thanks for your help
Post by Coopervid » Thu Dec 12, 2024 2:14 pm
MrMegadeth99 wrote: Thu Dec 12, 2024 2:10 pm Nevermind I got it thanks for your help
Did it work now?
Post by Billycar11 » Thu Dec 12, 2024 2:53 pm
where did you get those commands?
your copying my directory's thats not going to work
Post by Coopervid » Thu Dec 12, 2024 4:13 pm
Billycar11 wrote: Thu Dec 12, 2024 2:53 pm
Forget about it Billy. It seems that it finally worked but he didn't even say a thank you after he did things that were missing any logic.
MrMegadeth99
Post by MrMegadeth99 » Thu Dec 12, 2024 4:21 pm
Yes it worked not thanks.
What commands?
Bigou
Post by Bigou » Thu Dec 12, 2024 4:45 pm
d00zah wrote: Wed Dec 11, 2024 10:51 pmIs MakeMKV installed (in the default location)? SDFtool Flasher is a front-end for the MakeMKV native flash utility. Met all the requirements detailed on the SDFtool Flasher page?
Oh god, I’m an idiot! I forgot to install MakeMKV! THAT was the problem. Once installed, it worked as it should. Thank you for pointing to me what essential part I forgot. (And sorry for the double-post, I was under the impression my message wasn’t sent the first time.)
Bigou
Post by Coopervid » Thu Dec 12, 2024 4:56 pm
MrMegadeth99 wrote: Thu Dec 12, 2024 4:21 pm Yes it worked not thanks.
What commands?
The directory path you used in your power shell script: Billy blahblah. We are sure that directory doesn't exist on your computer.
MrMegadeth99
Post by MrMegadeth99 » Thu Dec 12, 2024 5:49 pm
No clue I just followed the YouTube video
