Pioneer BDR-UD03 UHD possibility
happydrunkgamer
Re: Pioneer BDR-UD03 UHD possibility
Post by happydrunkgamer »
Hello @Coopervid
If you provide any help that would be amazing, I have this drive :)
Details
OS device name: J:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8511
Firmware version: 1.14
Thank you :)
happydrunkgamer wrote: Tue Dec 10, 2024 11:29 pm Hello @Coopervid
Details
OS device name: J:
Revision: 1.14
Thank you :)
PM sent.
onyceeon
Post by onyceeon »
Hello @Coopervid, could you give me the details over PM?
Here's the details of my drive:
OS device name: /dev/sr0
Revision: 1.14
Highest AACS version: 63
I'm on linux, but I can use windows to flash it.
Thanks in advance!! :D
onyceeon wrote: Wed Dec 11, 2024 11:31 am Hello @Coopervid, could you give me the details over PM?
Revision: 1.14
PM sent. It will expire 14 days after being sent and not read.
onyceeon
Post by onyceeon »
Coopervid wrote: Wed Dec 11, 2024 8:25 pm
Revision: 1.14
Worked perfect!
Thanks!! :D
spooky77
Post by spooky77 »
Hello, I am in the same boat as everyone else in this thread too, here is my drive's information:
OS device name: F:
Revision: 1.14
Serial number:
I would appreaciate some help, thank you very much in advance!
spooky77 wrote: Thu Dec 12, 2024 6:18 am Hello, I am in the same boat as everyone else in this thread too, here is my drive's information:
OS device name: F:
Revision: 1.14
Serial number:
Pm sent. Will expire in 2 weeks.
spooky77
Post by spooky77 »
Coopervid wrote: Thu Dec 12, 2024 10:14 pm
OS device name: F:
Revision: 1.14
Serial number:
Thank you so much, it worked perfectly!
CofDiv
Post by CofDiv »
I have also the same problem with my BDR-UD03. Please need help :mrgreen:
CofDiv wrote: Fri Dec 13, 2024 3:23 pm I have also the same problem with my BDR-UD03. Please need help :mrgreen:
Post your Makemkv info.
EmreOe
Post by EmreOe »
Hello, I agree. I got this drive and wanted to insert my first UHD4K Bluray and it doesn't read it. Maybe you can help me. Thanks in advance
Infomation:
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: [redacted]
Firmware-Datum: 2020-06-15
EmreOe wrote: Sat Dec 14, 2024 10:03 pm Hello, I agree. I got this drive and wanted to insert my first UHD4K Bluray and it doesn't read it. Maybe you can help me. Thanks in advance
Infomation:
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.14
PM is coming.
EmreOe
Post by EmreOe »
Thank you :)
CofDiv
Post by CofDiv »
Coopervid wrote: Fri Dec 13, 2024 8:06 pm
Here it is:
CD location : /dev/sr0
CD driver name: GNU/Linux
access mode: IOCTL
Vendor : PIONEER
Model : BD-RW BDR-UD03
Revision : 1.14
Hardware : CD-ROM or DVD
Can eject : Yes
Can close tray : Yes
Can disable manual eject : Yes
Can select juke-box disc : No
Can set drive speed : No
Can read multiple sessions (e.g. PhotoCD) : Yes
Can hard reset device : Yes
Reading....
Can read Mode 2 Form 1 : Yes
Can read Mode 2 Form 2 : Yes
Can read (S)VCD (i.e. Mode 2 Form 1/2) : Yes
Can read C2 Errors : No
Can read IRSC : Yes
Can read Media Channel Number (or UPC) : Yes
Can play audio : Yes
Can read CD-DA : Yes
Can read CD-R : Yes
Can read CD-RW : Yes
Can read DVD-ROM : Yes
Writing....
Can write CD-RW : Yes
Can write DVD-R : Yes
Can write DVD-RAM : Yes
Can write DVD-RW : No
Can write DVD+RW : No
__________________________________
CofDiv
Post by CofDiv »
Here it is:
access mode: IOCTL
Vendor : PIONEER
Revision : 1.14
Can eject : Yes
Reading....
Can read IRSC : Yes
Can read CD-R : Yes
Writing....
