Why has make MKV stopped working with Mac?
natra
Post by natra » Fri Nov 29, 2024 7:22 am
Hi, I'm wondering why is make MKV not working anymore with Mac?
Re: Why has make MKV stopped working with Mac?
Post by dcoke22 » Fri Nov 29, 2024 7:24 am
natra wrote: Fri Nov 29, 2024 7:22 am Hi, I'm wondering why is make MKV not working anymore with Mac?
It is working on my Mac. In fact, it is running in the background as I type this.
What is happening on your Mac?
natra
Post by natra » Fri Nov 29, 2024 7:57 am
dcoke22 wrote: Fri Nov 29, 2024 7:24 am
On mine, it hasn't worked for months. I've only used my Windows computer. The problem that I am having is I can hear the disc is skipping about 2 to 3 minutes into the rip and then at the end it almost just stops.
Post by dcoke22 » Fri Nov 29, 2024 1:52 pm
Are you using the same optical drive on both your Mac and your Windows computer or does each computer have a separate optical drive?
And does your Mac have this behavior with 1 particular disc or with all discs that you try?
natra
Post by natra » Fri Nov 29, 2024 11:39 pm
dcoke22 wrote: Fri Nov 29, 2024 1:52 pm Are you using the same optical drive on both your Mac and your Windows computer or does each computer have a separate optical drive?
I only have one optical drive and it happens with every movie and I have a Mac mini M1.
Post by Billycar11 » Sat Nov 30, 2024 12:13 am
natra wrote: Fri Nov 29, 2024 11:39 pm
Probably a power issue.
What's the error show us the log
natra
Post by natra » Sun Dec 01, 2024 11:14 pm
Billycar11 wrote: Sat Nov 30, 2024 12:13 am
Thanks, man you were right. It was the power supply. It was not all the way in because I'm using adapter one thing I can recommend to everybody does ripping a lot is to buy a 5V fan and put it on top of the optical drive.
natra
Post by natra » Wed Dec 11, 2024 1:57 am
I thought I fixed the problem but when I watch some movies I saw it some parts of the movies just start to stutter and every time I try to rip on my Mac M1 about 1500 to 1700 M then I can hear the drive skipping I have tried different cables and it's all the same. Then I go to my windows with the same cables and I'm having no issues does anybody else have this problem?
