Can't Flash ASUS BW-16D1HT
Re: Can't Flash ASUS BW-16D1HT
Post by MartyMcNuts » Tue Dec 10, 2024 3:35 am
jlsohio24 wrote: Tue Dec 10, 2024 2:29 am Where can i find the older version? Thank you.
I provided the link to the thread in my previous post.
viewtopic.php?p=70766#p70766
jlsohio24
Post by jlsohio24 » Tue Dec 10, 2024 4:39 am
Got it now. Thanks.
jlsohio24
Post by jlsohio24 » Tue Dec 10, 2024 4:47 am
It did not work.
zittrig
Post by zittrig » Tue Dec 10, 2024 5:46 am
In Marty's link in his last post you'll find a further link to the modified ASUS flasher.
Edit: Oh, sorry, you've found it before. I've overseen that .... :?
jlsohio24
Post by jlsohio24 » Tue Dec 10, 2024 1:26 pm
Thank you. I found it. However, it did not work.
Post by Coopervid » Tue Dec 10, 2024 4:51 pm
jlsohio24 wrote: Tue Dec 10, 2024 1:26 pm Thank you. I found it. However, it did not work.
There are quite a couple of reasons why this doesn't work.
Drive not empty and/or tray not closed.
Third party SATA controller. Attach to mainboard SATA controller.
Some AMD SATA controllers can make trouble or when SATA is configured as RAID.
If AMD, try to connect the drive to an Intel board and to the mainboard SATA controller.
Last resort: Buy a BENFEI USB->SATA controller with power supply (<$20) and try that.
Always shut down the PC after flashing and wait a minute before powering up again.
CharlyTheSneaky
Post by CharlyTheSneaky » Sat May 17, 2025 1:19 pm
Hello, my drive is a BU40N and I'm having the same error code : 0x82052400
I've made sure that tray is closed, and no disc are inside
OS device name: E:
Product: BD-RE BU40N
Revision: 1.05
Highest AACS version: 77
So when flashing with SDF (v1.3.6), I've used these 3 files : DE_LG_BU40N_1.00.bin | DE_LG_BU40N_1.03_MK.bin | DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin
However, none worked, I've tried opening and closing, restarting, going to 1.3.5 version of sdf, nothing seems to fix it
Also the date you see on the "firmware date" is not a typo from my part, it is really written "2124"
What could be the issue? Should I send my drive back?
DavoBR
Post by DavoBR » Sat May 17, 2025 1:37 pm
CharlyTheSneaky wrote: Sat May 17, 2025 1:19 pm Hello, my drive is a BU40N and I'm having the same error code : 0x82052400
OS device name: E:
Revision: 1.05
I used DE_LG_BU40N_1.03_MK.bin (with Enc ticked) only two days ago without any issue.
CharlyTheSneaky
Post by CharlyTheSneaky » Sat May 17, 2025 3:58 pm
DavoBR wrote: Sat May 17, 2025 1:37 pm I used DE_LG_BU40N_1.03_MK.bin (with Enc ticked) only two days ago without any issue.
Ok so it worked but on SDF 1.3.5 not 1.3.6 but thanks for the heads up!
After flashing :
OS device name: E:
Revision: 1.03
Serial number: XXXXXXXX
Firmware version: 1.03
coldfire05
Post by coldfire05 » Wed May 21, 2025 9:52 am
Coopervid wrote: Mon Dec 09, 2024 5:52 pm
jlsohio24 wrote: Mon Dec 09, 2024 4:54 pm OK, I got it working with ver 3.11.
Firmware version: 3.11
Is that ok to have 3.11?
There is no 3.11 to flash for the BW-16. What did you do? Flash the BC-12? That's bad! Try again another flash to BW16 3.10 without enc checked.
Bad = you can't burn BD's because the BC12 is a combo and can only read BDs but not burn. So flash to BW-16 3.10.
I hate when people are doing things they have no clue what they are doing.
this is called learning
