Can't Flash ASUS BW-16D1HT
jlsohio24
Post by jlsohio24 » Sat Dec 07, 2024 4:10 pm
I have an ASUS BW-16D1HT drive.
I downloaded the SDF Tool Flasher and All You Need Firmware Pack.
When I open SDF Tool Flasher and select my drive: M: ASUS_BW-16D1HT_3.10_211901041014_KLCL75J0941
The MT1959 Platform has a green check mark. The encrypted firmware does not. It has a red X.
When I click on the Firmware to write pull down, I get 3 Asus choices: DE_ASUS_BC-12D2HT_3.11_MK.bin, DE_ASUS_BW-16D1HT_3.02bin or DE_ASUS-16D1HT_3.10MK.bin.
None of them worked.
Command code error: 0xff05c103.
How can I flash this drive?
Thank you.
Re: Can't Flash ASUS BW-16D1HT
Post by Billycar11 » Sat Dec 07, 2024 9:40 pm
Check the enc thing and it should work
jlsohio24
Post by jlsohio24 » Sat Dec 07, 2024 9:48 pm
OK, I checked the box. Ran the tool. Got this error: 0x82052400.
I tried updating to 3.11 and 3.10
Post by Billycar11 » Sat Dec 07, 2024 9:51 pm
See guide below and tell use what that does
Use the command line flasher
Post by MartyMcNuts » Sat Dec 07, 2024 10:10 pm
Thank you.
Make sure there is no disc in the drive and the tray is closed. Also, 3.10 is the one you want to flash. Your drive does not have encrypted firmware.
jlsohio24
Post by jlsohio24 » Mon Dec 09, 2024 4:54 pm
OK, I got it working with ver 3.11.
Firmware version: 3.11
Is that ok to have 3.11?
Post by Coopervid » Mon Dec 09, 2024 5:52 pm
There is no 3.11 to flash for the BW-16. What did you do? Flash the BC-12? That's bad! Try again another flash to BW16 3.10 without enc checked.
Bad = you can't burn BD's because the BC12 is a combo and can only read BDs but not burn. So flash to BW-16 3.10.
I hate when people are doing things they have no clue what they are doing.
jlsohio24
Post by jlsohio24 » Mon Dec 09, 2024 10:05 pm
OK, my bad.
I flashed it again with BW16 3.10 without encryption. It said it was 100% successful. However, when I open the MakeMKV software the drive still says BC-12 and firmware ver 3.11.
OS device name: G:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.11
Serial number:
Firmware date: 2119-02-27 13:19
Bus encryption flags: 1E
Highest AACS version: 78
Post by MartyMcNuts » Mon Dec 09, 2024 11:38 pm
OK, my bad.
OS device name: G:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.11
Serial number:
Use the recovery option of SDFtool Flasher. In the popup, select the current BC-12D2HT 3.11-MK you flashed, then in the firmware selection drop down box select BW-16D1HT 3.10-MK
jlsohio24
Post by jlsohio24 » Tue Dec 10, 2024 12:22 am
OK. Using the recovery option: I selected my current firmware: BC-12D2HT 3.11 mk. Then I also selected my flash firmware: BW16D1HT 3.10 mk
It was successful. However, nothing changed. Do I have to reboot? Thank you.
Post by Woodstock » Tue Dec 10, 2024 12:23 am
Did you power the drive off to get it to reload the software?
jlsohio24
Post by jlsohio24 » Tue Dec 10, 2024 12:30 am
No. I will do that now. Thank you.
jlsohio24
Post by jlsohio24 » Tue Dec 10, 2024 12:41 am
I powered it down. But it still did not work.
Post by MartyMcNuts » Tue Dec 10, 2024 1:19 am
These types of issues have occured quite a few times with that BC-12D2HT firmware. You might be stuck with it now...
You could try using the old modified ASUS flasher and see if that works. As you already have the firmware files, just download the modifed ASUS flasher (bottom of first post)
viewtopic.php?p=70766#p70766
Just select the drive, select the BW-16D1HT 3.10-MK firmware and start.
jlsohio24
Post by jlsohio24 » Tue Dec 10, 2024 2:29 am
Where can i find the older version? Thank you.
