External unit with HDMI & USB connections
Jango
Post by Jango »
Hello , I am looking for an external unit reader which should be compatible with MakeMKV and any DVD, BR and UHD format, which sports both HDMI out and USB-C.
This would be a perfect unit also to play discs when attached to a TV. I don't need a burner. Impossible? I leave in Italy
Re: External unit with HDMI & USB connections
Jango wrote: Mon Dec 09, 2024 11:18 am Hello , I am looking for an external unit reader which should be compatible with MakeMKV and any DVD, BR and UHD format, which sports both HDMI out and USB-C.
HDMI out is not possible. You can play via PC / Laptop with HDMI out or you can rip the discs and then play with a player feeding your TV e.g. NVIDIA Shield, Oppo Clone etc.
Jango
Post by Jango »
Thanks. Assuming i would be interested to move copies of my DVDs and BRs to my NAS using Makemkv (no burning required), what portable USB-C reader could I buy ti rip DVD, BR &UHD for the future?
Jango wrote: Mon Dec 09, 2024 2:15 pm Thanks. Assuming i would be interested to move copies of my DVDs and BRs to my NAS using Makemkv (no burning required), what portable USB-C reader could I buy ti rip DVD, BR &UHD for the future?
What's your country of residence?
exitguy
Post by exitguy »
Coopervid wrote: Tue Dec 10, 2024 10:07 am What's your country of residence?
Last sentence in the first OP post !!
exitguy wrote: Tue Dec 10, 2024 10:14 am
This works out of the box without flashing for UHD.
https://www.amazon.it/Verbatim-43888-Bl ... %3D&sr=8-2
Coopervid wrote: Tue Dec 10, 2024 10:19 am
Only if it's not the LG BU40N version!! If so, it will require flashing.
MartyMcNuts wrote: Tue Dec 10, 2024 11:10 pm
Understood Marty. Until now no Verbatims 43888 with the LG drive have surfaced in Europe, however. But it might be just a matter of time.
Jango
Post by Jango »
I can I know this before buying?
xtractor
Post by xtractor »
I ordered the Verbatim 43888 last week from Amazon Sweden, it arrived on Thursday. Mine has the Pioneer drive with firmware UD04 version 1.14. It was indeed LibreDrive out of box and I successfully ripped Creed 2 in 4K. 🫡
Jango wrote: Wed Dec 11, 2024 11:21 am
No. Not unless you can get the seller to show you a picture of the bottom of the box.
See here: viewtopic.php?p=164009#p164009
Jango
Post by Jango »
Well, I've bought the unit! How can I test, once delivered, if it works without flashing?
Jango wrote: Thu Dec 12, 2024 10:55 am Well, I've bought the unit! How can I test, once delivered, if it works without flashing?
Check / post your Makemkv info. If Pioneer it works right away, if LG it must be flashed.
Example for the Pioneer:
OS device name: /dev/rdisk4
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Drive platform: RS8A10
Firmware version: 1.14
Jango
Post by Jango »
I am confused since in your previous post you have stated that the above LG unit will not require flashing!
Jango wrote: Thu Dec 12, 2024 11:21 am
Until now the Verbatim in EU always contained a Pioneer drive. In Australia just recently one surfaced with a LG drive. I haven't seen one in EU. So your chances are very high you get a Pioneer.
