So I got a ASUS BW-16D1HT with FW 3.01 Do I need to flash it?
ShadoWalkeR
Post by ShadoWalkeR »
So I've been searching for a drive to rip all my media here for quite a bit and finally found a ASUS BW-16D1HT on Ebay for cheap here in Europe.
The seller said it's: "ASUS BW-16D1HT Blu-Ray Drive with Firmware 3.01 "UHD Friendly""
And on the description he said it's compatible with MakeMKV, so should I still flash it to the 3.10MK?
I'm new to this help is appreciated :)
Re: So I got a ASUS BW-16D1HT with FW 3.01 Do I need to flash it?
ShadoWalkeR wrote:
Sun Dec 08, 2024 5:46 pm
No need but do what you want.
ShadoWalkeR
MartyMcNuts wrote:
Sun Dec 08, 2024 8:24 pm
Is there any advantage at all to go to 3.10MK? Like better speeds or better UHD Compatibility?
ShadoWalkeR wrote:
Mon Dec 09, 2024 12:09 pm
3.10 rips faster, 3.01 up to 3.03 is better with critical discs and stays longer at slower speed if reading is a problem. Your choice.
