MakeMKV does not proceed beyond downloading SDF
fosskers
Re: MakeMKV does not proceed beyond downloading SDF
#16 Post by fosskers » Sun Dec 08, 2024 6:33 am
I tried using the `_private_data.tar` you linked, but it didn't work for me. The `makemkvcon guiserver` process still spins forever at 100%.
DukeFleed
#17 Post by DukeFleed » Sun Dec 08, 2024 7:46 am
@dcoke22
Thanks, I didn't know that. I think even though it hasn't been tested, it should work for others who have this problem.
spliffit
#18 Post by spliffit » Tue Dec 10, 2024 7:46 am
I had exactly the same symptoms, my internal LG disc drive locked up at the same point. Unfortunately, I don't have access to an older version of MakeMKV, but I found that if I used my old Samsung USB disc drive instead everything burst into life. If I tried to use the internal drive afterwards, the application locked up and the only way I could get the USB drive to work was to restart the the application.
tommyS
#19 Post by tommyS » Thu Dec 19, 2024 6:22 pm
can confirm, 1.17.8 does not work. using the private_data from a previous system did not work either.
what worked was downgrading back to 1.17.7.
the download links for both packages are the same as the current links pointing to the 1.17.8 versions, just replace 1.17.8 with 1.17.7.
like so:
https://www.makemkv.com/download/makemk ... 7.7.tar.gz
lemmegetsomemovies
#20 Post by lemmegetsomemovies » Sun Feb 02, 2025 9:54 pm
I have this exact issue on Fedora 41 on multiple machines with 1.17.9 from both FlatHub and manual install.
It works perfectly on an old macbook air I have laying around, which is the only saving grace right now.
It's clearly not the drive or the machine, it's the MakeMKV build.
mirto
#21 Post by mirto » Sun Feb 16, 2025 6:08 pm
Hi all,
I have the same problem with MakeMKV 1.17.9 on Manjaro stable updated to today.
What I've found:
* MakeMKV starts correctly without a disk
* iserting a disk results in an infinite loop
* copyng the disk with dd creating an ISO image and giving the image as input to MakeMKV works correctly and generates the MKV files
The window with the loop
The makemkvcon info (interrupted with CTRL+C) and the log
   ~/Video  LANG=C makemkvcon info dev:0 --debug=makemkv_debug.txt         ✔
MakeMKV v1.17.9 linux(x64-release) started
Debug logging enabled, log will be saved as file:///home/mirto/MakeMKV_log.txt
DEBUG: Code 0 at %!`0:r|CkMG!# EZc^amvu:29393631
^C
    ~/Video  cat /home/mirto/MakeMKV_log.txt         INT ✘  2m 1s 
Debug log started at Sun Feb 16 17:50:50 2025 , written by MakeMKV v1.17.9 linux(x64-release)
001005:0000 MakeMKV v1.17.9 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/mirto/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.12.1/OpenSSL/3.4.0/1.64.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at %!`0:r|CkMG!# EZc^amvu:29393631
No  SDF v098: HL-DT-ST_BD-RE__BH16NS55_1.05_212006181342_KLFL1BJ2441
SDF auto v098: HL-DT-ST_BD-RE__BH16NS55_1.05_212006181342_KLFL1BJ2441
    ~/Video          ✔
Any suggestion?
mirto
#22 Post by mirto » Sun Feb 16, 2025 6:37 pm
tommyS wrote: Thu Dec 19, 2024 6:22 pm can confirm, 1.17.8 does not work. using the private_data from a previous system did not work either.
like so:
the links give a 404 error
Seems this version is no more accessible
#23 Post by d00zah » Sun Feb 16, 2025 7:27 pm
mirto wrote: Sun Feb 16, 2025 6:37 pm ...
They've been archived. Old versions available here.
mirto
#24 Post by mirto » Sun Feb 16, 2025 7:38 pm
d00zah wrote: Sun Feb 16, 2025 7:27 pm
lavalaugh
#25 Post by lavalaugh » Mon Mar 10, 2025 7:16 pm
I found a workaround. At least for my system.
MakeMKV does still work with a USB DVD drive. I tested it with a no-name Maxxter DVD drive.
rstevenson1976
#26 Post by rstevenson1976 » Sat Jun 07, 2025 1:53 am
Debug log started at Sat Jun  7 01:41:51 2025 , written by MakeMKV v1.18.1 linux(x64-release)
001005:0000 MakeMKV v1.18.1 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/randall/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at *s,+4m-r">yFd&'k/Y<sa&:29393631
No  SDF v098: ASUS_BW-16D1X-U_A105_212012021114_KLCN52E2603
SDF auto v098: ASUS_BW-16D1X-U_A105_212012021114_KLCN52E2603
happened to me too, identical log output
duanerob
#27 Post by duanerob » Mon Jun 30, 2025 4:56 am
I got this same issue, with a debug output just like rstevenson1976's after installing a new ASUS BW-16D1HT. I was using version 1.18.1, and makemkv seemed to just lock up after the bios message. Fortunately, I happened to have a copy of 1.17.7 in my pacman cache, so I installed it, and makemkv ran the drive normally.
Then I flashed the drive's bios to the 3.10 mk version (asus-bw-16d1ht-3.10-wm01601-211901041014.bin) from the stock 3.11 (still using makemkv 1.17.7). Again, the drive worked fine with makemkv 1.17.7, but it also worked fine when I reinstalled makemkv 1.18.1.
So I'm guessing that the newer versions of makemkv have problems with the newer asus bios. I think I'll hang on to a copy of 1.17.7, just in case.
nick_adams
#28 Post by nick_adams » Tue Sep 02, 2025 7:51 pm
Hi all,
the same problem here with version 1.18.1. Version 1.17.7 works (haven't tried 1.17.8 and 1.17.9). Distribution is Debian 13 Trixie and optical drive is HL-DT-ST BD-RE BH10LS30 from Hitachi LG.
PixpixBle
#29 Post by PixpixBle » Wed Nov 05, 2025 8:14 pm
I also had a problem with the 1.18.2 binary (Kubuntu 24 LTS) and HL-DT-ST_BD-RE BH16NS55 1.05.
I don't have previous logs, but the program was "blocked" on:
OK - "SDF auto v098: HL-DT-ST_BD-RE__BH16NS55_1.05_212006181342_KLTNBHE4507" - last line in old log
NOK - "003332:0000 Saved FW dump file as .MakeMKV/dump_FW_38AD22B8E13B299FFE3E.tgz"
NOK - "003347:0000 Please send the file ".MakeMKV/dump_FW_38AD22B8E13B299FFE3E.tgz" to support@makemkv.com"
Version MakeMKV v1.17.7 linux(x64-release) works perfectly.
