So i got the Pioneer BDR-212DBK and here is the information about it in MakeMKV
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: [redacted]
Firmware date: 2022-03-16
Bus encryption flags: 13
Drive platform: RS8F00
Firmware version: 1.02/ID61
Do i need to install a firmware patch? I could not find a download for it and if so are the instructions that of the "how to install" page?
Got a BDR-212DBK. need firmware?
Re: Got a BDR-212DBK. need firmware?
if you want it to UHD email me see below for details
ddockrx
I also have this drive. After reading through several posts about UHD compatibility, I could find only one other that shared the same info as mine with a firmware getting ever so close to the 12/22 point of no return.
Revision: 1.03
Serial number: -omitted-
Firmware date: 2022-10-13
Highest AACS version: 81
Firmware version: 1.03/ID61
Can mine still be flashed to UHD friendly? I also have a BDR-209DBK in another computer. Is that one too old?
Revision: 1.03
bri4jenn
How do I flash a Pioneer BDR-212DBK optical drive to use MakeMKV with UHD discs.
Revision: 1.00
Serial number: BBDLXXXXXXWL
Firmware date: 2019-01-10
Highest AACS version: 82
Firmware version: 1.00/ID61
Revision: 1.00
bri4jenn wrote: Sun Sep 27, 2026 1:45 am How do I flash a Pioneer BDR-212DBK optical drive to use MakeMKV with UHD discs.
Revision: 1.00
sure email me that info and all others email me no need to post your info here just reach out to me directlyddockrx wrote: Thu Jan 02, 2025 9:33 pm I also have this drive. After reading through several posts about UHD compatibility, I could find only one other that shared the same info as mine with a firmware getting ever so close to the 12/22 point of no return.
Revision: 1.03
see below for email
PM sent.BoloinaBox wrote: Sun Dec 08, 2024 1:16 am So i got the Pioneer BDR-212DBK and here is the information about it in MakeMKV
OS device name: E:
Revision: 1.02
PM sent. Please post the Makemkv info for your 209 as well. Flash to UHD possible.ddockrx wrote: Thu Jan 02, 2025 9:33 pm I also have this drive. After reading through several posts about UHD compatibility, I could find only one other that shared the same info as mine with a firmware getting ever so close to the 12/22 point of no return.
Revision: 1.03
PM sent.bri4jenn wrote: Sun Sep 27, 2026 1:45 am How do I flash a Pioneer BDR-212DBK optical drive to use MakeMKV with UHD discs.
Revision: 1.00
