Dump Submitted - Deadpool and Wolverine 4K
Gryphon
Re: Dump Submitted - Deadpool and Wolverine 4K
#31 Post by Gryphon » Sat Nov 09, 2024 11:18 pm
MrPenguin wrote: Wed Oct 23, 2024 10:30 pm
WAYFLIX wrote: Wed Oct 23, 2024 10:24 pm Lower case keybd.cfg works just fine on MacOS.
Hmm, that's not my understanding of how a UNIX-based operating system behaves... Can you confirm that MakeMKV is actually using the KEYDB.cfg file please, i.e. by moving the file out of the data directory, restarting MakeMKV and trying to decrypt your disk again? It occurs to me that MakeMKV might also have added your key to its hashed keys.
I know it's been a couple weeks, but just to clarify. By default disks are not formatted as case sensitive on Mac OS. It's possible to do so (at least with APFS and IIRC with HFS+ as well) but it's not recommended unless you have a very specific need for it. The default formatting will respect whatever case you want to use but "KEYDB.cfg" and "keydb.cfg" would not be considered unique file names and you could not have both of them in the same directory.
lfoust
#32 Post by lfoust » Sat Dec 07, 2024 10:57 pm
I was able to rip the US version from Amazon - this is how it layed out for me: https://thediscdb.com/movie/deadpool-an ... es/2024-4k
eksine
#33 Post by eksine » Sat Dec 14, 2024 5:14 am
just a heads up I couldn't get it to work until I realized about adding the keydb.cfg in the C:\ProgramData\aacs\ directory, which is HIDDEN by default in windows. unhide system files and you will see it. also VLC has 32 bit and 64 bit versions of libaacs.dll which you have to put in the VLC program folder. makemkv started ripping fine as soon as I did that. click the windows icon in the bottom tray of icons and run a search for: show hidden files. mine is windows 11
https://vlc-bluray.whoknowsmy.name/
Wonder how to get your VLC 3.0 to play encrypted blu-ray discs? Here's how.
You'll need two files: keys database and AACS dynamic library.
Keys database
Fetch the up-to-date file from FindVUK online database and unzip it
Windows: put it in C:\ProgramData\aacs\
Mac OS X: put it in ~/Library/Preferences/aacs/ (create it if it does not exist)
Linux: put it in ~/.config/aacs/
Linux SNAP: put it in ~/snap/vlc/current/.config/aacs/
UPDATED 25-03-2018!
VLC 32 bit on Windows: put that file in your VLC directory
VLC 64 bit on Windows: put that file in your VLC directory
Mac OS X: put that file in /usr/local/lib/ directory (create it, if it does not exist)
Linux: install libaacs package using your distribution package manager.
A7omicbomb
#34 Post by A7omicbomb » Thu Dec 19, 2024 10:50 pm
Submitted a dump file for Japanese 4K (3D set)
MKB20_v77_MARVEL_STUDIOS'_DEADPOOL_AND_WOLVERINE_5CB0
