The Crow (1994) Paramount Pictures Wide Release Steelbook 4K UHD Dump File
GasmaskAvenger
Post by GasmaskAvenger » Sun May 19, 2024 3:01 pm
MakeMKV is unable to open this one for me, so sent the dump file to the necessary place. Cheers!
MKB20_v77_CROW_REMASTERED_5F0C
Jack_The_Ripper
Re: The Crow (1994) Paramount Pictures Wide Release Steelbook 4K UHD Dump File
Post by Jack_The_Ripper » Sat Dec 07, 2024 4:37 pm
Just tried ripping this movie and it doesn't work. It's stuck at about the 45min mark in the ripping process and my drive is going crazy.
Post by Woodstock » Sat Dec 07, 2024 6:41 pm
"doesn't work" can mean many things. Your description seems to indicate that the decoding starts (they key is valid), but an error is encountered later. Usually, these are read errors, and cleaning the disk helps a LOT in these cases.
Jack_The_Ripper
Post by Jack_The_Ripper » Sun Dec 08, 2024 12:34 am
Apologies for being a bit vague.
The disc is brand new. It came out of the plastic and went into a brand new Pioneer drive so I am not completely sure what is happening towards the end. I did see that the allotted time for completion went from 12mins to nearly 2 hours and my drive was making noises that seemed to signal it was struggling to read. After about 25mins, I decided to cancel the process.
Post by Woodstock » Sun Dec 08, 2024 1:36 am
OK, then the disk isn't one with a different key; MakeMKV started to read it.
However, somewhere in the process, it hit a difficult-to-read section, which it's trying VERY HARD to read. Most drives will time-out when this happens, but some don't seem to. The main thing is to try cleaning the disk, as that is likely the problem. With UHD disks this happens sooner than with regular Bluray, but any disk that has sat in the package for 6 months or more is suspect, and should be cleaned with a soft, damp cloth. They make microfiber disk cleaning cloths for this sort of thing,
You clean ACROSS the read path (center to edge, not around the disk). Usually, you can see a difference with the first wipe.
Jack_The_Ripper
Post by Jack_The_Ripper » Sun Dec 08, 2024 3:04 am
Thank you for the response and the advice.
Strangely, I popped the disc back in just a little while ago and gave it another try. It completed the rip without a hitch. An unexplainable random event that befell the first attempt? Who knows.
Nonetheless, I will keep your advice in mind as I go through my library. This is the first time I am digitizing it and I have somewhere in the realm of a thousand discs ahead of me - about 40% of those being UHDs with about 15% of them still in the plastic.
Thanks again.
stamatis87
Post by stamatis87 » Mon Dec 30, 2024 2:02 pm
Was able to rip this disc with no issues but both Kodi and Plex aren't reading the DTS-HD Master 5.1 track. It only plays the core DTS 5.1 track.
Put the disc in a player and it does output DTS-HD Master Audio 5.1. Tried ripping twice but same result.
This is the first movie I've come across where the DTS-HD Master Audio 5.1 track in unplayable.
Anyone else having this issue?
Vintrus
Post by Vintrus » Wed May 14, 2025 10:52 pm
Yep I have had the same issue standard release (USA) I also bought the Australian release to make sure it was just a US Issue got the same problem. its Paramount master issue and I have never seen this with any other release.
stamatis87
Post by stamatis87 » Thu Jun 26, 2025 1:34 pm
As a workaround for now I've just ripped the M2TS file with Xreveal and the DTS-HD Master Audio 5.1 track now plays fine with Kodi.
ben_uk
Post by ben_uk » Sat Jun 28, 2025 5:44 pm
I had to insert American Psycho literally about 50 times over the course of 3-4 days in order for it to finally work in my LG drive.
t-force
Post by t-force » Sat Feb 07, 2026 4:03 pm
With apologies for resurrecting a very dead thread: I've had the same issue with The Crow, and the problem appears to be down to the fact that the .mkv is created with a massive 6006 ms audio offset. I used mkvtoolnix to remux it without the delay, but now, not hugely surprisingly, the audio and video are badly out of sync.
Were you able to do anything with the 00294.m2ts file, once you'd used Xreveal to get it off the disc? I've done that bit, but never ripped a disc in this way, so I'm unsure what step comes next.
t-force
Post by t-force » Sun Feb 08, 2026 4:45 pm
Got it fixed in the end (after a suggestion from ChatGPT): extracted the DTS-HD MA soundtrack using eac3to, then used eac3to again to re-insert the audio into a new .mkv file. Now got the full-fat soundtrack, properly synced.
